Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-04-2005, 10:11 PM
masterzzz masterzzz is offline
Smile How to change Fuel Filter
Hi!
I am a newbie..and want to change my fuel filter myself as my dealership is try to rip me off.
I have a 2000 Civic EX Coupe
Can you experts out there post a quick guide for me so that I can do it this weekend?
Thanks for you help, boys & girls
Old 02-05-2005, 12:50 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Replacement
WARNING:
Do not smoke while working on fuel system. Keep open flame away from your work area.
While replacing the fuel filter, be careful to keep a safe distance between battery terminals and any tools
-Open the gas cap, and vent some of the built up pressure.
-Place a shop towel under and around the fuel filter.
-Relieve fuel pressure.
-Remove the 12 mm banjo bolt and the fuel feed pipe from the fuel filter, while supporting it with the another wrench, as shown.
-Remove the fuel filter clamp and fuel filter.
Install the new fuel filter in the reverse order removal, and note these items:
When assembling, use new washers as shown.
Clean the flared joint of high pressure hoses thoroughly before reconnecting them.
Old 02-05-2005, 02:22 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Can't get much better than that, great post Kris.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 02-05-2005, 07:37 AM
wow, thanks I lot!
Old 02-05-2005, 10:51 AM
kris's Avatar
Re: How to change Fuel Filter
Old 02-16-2005, 05:31 PM
bluehaze13 bluehaze13 is offline
To relieve the fuel pressure:
1.Locate the fuel pump electrical connector which is underneath the back seat so you have to pull the seat out. There you will find a large thin cover, underneath is the fuel pump... disconnect the wires.
2. Start the engine, let it run until it stalls.
3. Unscrew the fuel filler cap to relieve any pressure.
Buy a Haynes Repair Manual. It's helped me with my Civic. If you want to check it out go to www.cardomain.com/id/bluehaze13
Old 02-18-2005, 10:22 AM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
How many miles should you put on it before you replace it? 50-60,000 sound rite?
Old 02-18-2005, 10:30 AM
Honda says every 30,000 miles. But I changed mine around 55k. No big deal. I wasn't having any performance issues, I just replaced my fuel rail with an AEM one and put in an AEM adjustable fuel pressure regulator. I figured I might as well be safe, and go the extra mile. You can buy an oem fuel filter from any autoparts store for about 20 bucks. Good luck!
