Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 02-04-2005, 09:08 PM
Guru_37's Avatar
Guru_37 Guru_37 is offline
Cool ECT - What Does It Do?
Checking up on ECT (Electronic Control Transmission) and I was wondering, what are the benefits of it? Would it be a good idea to use it in the snow time when it gets slippery? I thought it may help as another form of traction control.
Old 02-17-2005, 12:38 AM
Joe W Joe W is offline
Re: ECT - What Does It Do?
All this does is change the shift points in the transmission. It would have no effect on the traction control, except that you want it to upshift as soon as possible in the snow.
Old 02-19-2005, 03:13 PM
Akshay Akshay is offline
I have ECT turned on the freeway. I helps with making quick passes.
I don't like having ECT turned on all the time. It takes the tranmission forever to shift.
Old 04-19-2005, 07:27 PM
Diamond_Jim Diamond_Jim is offline
Re: Re: ECT - What Does It Do?
it also effects gas milage especially in-town. Beacuse it winds the engine out farther in each gear, it burns more fuel.
Old 08-01-2005, 07:01 PM
ecarlson's Avatar
ecarlson ecarlson is offline
I now leave my ECT in power mode all the time on my 97 Avalon XLS, because it fits better for the way I drive. I also graphed my gas mileage over many months in each mode, and there was no difference. It was about 23.MPG average either way. I also compared regular gas to premium, and it was also the same MPG, and I didn't really notice any performance difference (but that doesn't stop me from using premium now anyway).
My previous car, an 89 Mazda 626, 5-speed, also graphed the same MPG (32.MPG) over many months with regular vs premium, but eventually I had to use premium to keep it from pinging under medium-hard accelleration.
- Eric, www.InvisibleRobot.com
Old 08-01-2005, 10:51 PM
Guru_37's Avatar
Thankz for the reply bro, it's interesting how we have the same year and model car. 1997 Toyota Avalon XLS, one problem my cd changer doesn't work? the cd button doesn't engage the cd player and the cd changer doesn't eject the cds. Overall great car
Old 08-01-2005, 11:04 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
http://www.automotiveforums.com/vbul...d.php?t=128958
Just read my posts there. Explains all you need to know.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 01-24-2008, 09:19 AM
AmercanMuscle92 AmercanMuscle92 is offline
ECT- the button that can turn a mild sedan into a sporty sleeper (w/ a few other mods)
this button moves the shift points to higher rpms, but it varies on gas input and acceleration.
i drive a 96 avy XLS and recently adjusted my tranny to shift faster and harder this sucked w/ ect off b/c the trans would shift earlier and make the car fell slow and clunky.
i drive w/ it on all the time it really will give you a power advantage. this applie only to drivers who regularly drive in high rpm ranges and use their cars to full capacity.
when on this switch will allow the engine to redline under heavy load and will also allow the engine to downshift to achieve better acceleration(downshifts from say 3rd at 3000rpm to 2nd at 5000rpm)
as for fuel consumption this switch makes the car GUZZLE gas but then again i have a heavy foot and wont hesitate at laying the pedal to the floor at stoplights.
so
in short
ECT=more acceleration=more power= more gas= more engine wear
use it if you like that sporty feeling and the look on the guys face after you smoke his beamer
peace
Old 01-26-2008, 09:49 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
It is poor form to respond to posts this old.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
