Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-03-2005, 05:52 PM
LBniner LBniner is offline
quick ? about boost control
when you have an automatic boost controller can you simply change the boost in terms of psi from inside the car?
is it possible to cause problems by changing the boost too often? (hypothetically, if you changed the boost every time you drove could anything go wrong?)
Old 02-03-2005, 11:10 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: quick ? about boost control
What do you mean by "automatic boost controller"? Are you talking about a manual boost controller or an electronic boost controller?
There are quite a few boost controllers that you can adjust from inside the car (obviously including the electronic ones). One problem with constantly changing your boost is that the engine won't be properly tunes for ignition and air/fuel. If you really want to change the boost, I'd suggest either 1)getting it professionally tuned to 2 different boost ranges and have them tell you where to adjust it to or 2)get it professionally tuned and spend the $ to get an electronic boost controller, so you can adjust it properly. But constantly changing it for different boost levels would be a bad idea.
Old 02-04-2005, 01:07 PM
oops
i meant electronic. i was thinking automatic as opposed to manual. but thanks civicspoon, thats what i was asking.
Old 12-30-2005, 04:45 AM
r334door r334door is offline
Send a message via ICQ to r334door Send a message via MSN to r334door
has anyone put a blitz boost controller in and come across an error message E03?
Old 12-30-2005, 10:32 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Re: Re: quick ? about boost control
don't post in old threads, start a new one asking your question.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 12-30-2005, 04:53 PM
Unhappy Re: Re: Re: quick ? about boost control
sorry only new on this an wasnt sure how to start a new post
