Old 02-04-2005, 09:19 PM
Sp3cops70's Avatar
Sp3cops70 Sp3cops70 is offline
Send a message via AIM to Sp3cops70 Send a message via MSN to Sp3cops70 Send a message via Yahoo to Sp3cops70
I need some help PLEASE??
Just today my A/C won't come on when i place it on the #1, 2, 3, and 4 positions.....but when i put it on #5 it does work. Only on Max not on low ,medlow, etc. Only 5. Why???
And also at night when the headlights come on automatically....they go off when i put the A/C on 1, 2, 3, and 4 not #5....any ideas....it may be an electrical problem....all this started happening today???
What do you all think it might be on these two problems i am having???
97 GPGT 3.8 L.
Old 02-04-2005, 10:22 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: I need some help PLEASE??
Try this
http://www.automotiveforums.com/vbul...ghlight=blower
97 GPGT 3.8 L.
Old 02-04-2005, 10:37 PM
carlos80 carlos80 is offline
could be your resistors assem.the way gm changes the speed of the blower motor is through resistors the only speed that does not run through the resistor assembly is five in which battery voltage is applied to the motor
Old 02-05-2005, 11:15 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Id try replacing the blower motor resistor first and see if that helps with the problem of the light's since that is the cheapest way to go.If that dosent work then you will need to replace the ignition harness.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-06-2005, 06:04 PM
cajun david cajun david is offline
The hood release cable broke on my 94 grand prix. How can I get the hood to open
Old 02-06-2005, 08:27 PM
Larry,
Did I send the wrong one? Thought you covered the blower resistor in the thread I sent.
~Larry~
