Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-04-2005, 07:48 PM
tuanphan@yahoo tuanphan@yahoo is offline
sticky throttle/gas pedal
My 97 Maxima recently developed a sticky gas pedal. It sticks at first then frees up if I push hard enough with my foot. It's only sticky at the start of pedal travel, and is smooth after that. I did a quick inspection of the throttle cable but didn't see anything that might bind it. Does anyone have a suggestion on what to check? Thanks in advance.
tp
Old 02-05-2005, 06:31 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: sticky throttle/gas pedal
tp
Look hard at the rubber bits near TB, in the cable shroud ends: wire might stick theres if loose bits. At least dangerous if rubber bits falls off and jams.
Thread self vulcanizing rubbertape around that & lithium -lubricate the wire. After lubrication wipe excess grease off. Lubricate also cabin end.
For test purposes disconnect cruise ctrl cable.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 02-09-2005, 04:24 PM
gacorisle gacorisle is offline
tp
the gas pedal pedal sticks because there is carbon build up in the throttle plate. to correct problem remove the air duct to throttle body,
spray throttle body and plate cleaner (you can buy any auto store) and w/ a brush remove any black carbon. if you have air pressured, apply to evaporized the cleaner and avoid the vehicle to be flooded or backfires. otherwise let it sit for 5 minutes.
