Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-04-2005, 07:16 PM
jrgreen06 jrgreen06 is offline
Left turn signal
I have a 87 Crown Victoria and my left turn signal does not flash, however the right does. A continous light comes on when I signal. Would that be caused by a flasher or a bulb. I thought it might be a flasher because the front and rear do not work.
Old 02-04-2005, 07:20 PM
Jeffreytcole Jeffreytcole is offline
One of your bulbs is probably burned out (either the front or the rear) or at least the turn part of it. The flasher controls all "flashing" so if the right works then the flasher is good. Try changing your signal bulbs and that "should" fix the problem
Old 02-04-2005, 07:48 PM
Re: Left turn signal
Thanks, I'll give it a try on tomorrow.
Old 02-07-2005, 05:07 PM
Oops
Well, I thought that if your flasher worked on one side it would work on the other..... I was wrong. I thought I had a bulb out on my 85 cv and replaced it today so the right t/s would work and it doesn't. The left one works and the four ways all light up and flash just not the right t/s. If you figure it out please post Good luck
Old 08-18-2005, 12:38 PM
Mysanity Mysanity is offline
jrgreen06,
your problem is the turn signal flasher inside the fuse box. I had the exact same problem as you. Replaced the 2$ signal flasher & all is well.
