Power Antenna
Has anyone ever removed the Power Antenna from a 94 ZJ. I need to know where the F&#@ the Antenna Cable and Electrical Connector is under the dash, I have the haynes manual and yea it does not show anything even close to where it is actually located.
Try the kick panel on passenger side that's where my 93 had the Ant. wire and a few elect.connections
Re: Power Antenna
I looked in that spot, I could not find nothing, thats exactly where the Haynes Manual says to look fit it at.
Re: Power Antenna
was the Ant. in the 93 a Power Ant. or just set.
The ant. wires pass into the truck on right passenger side behind kick plate. you should see them when you remove the cover. If i remember correctly it's high up near bulkhead.
You should be able to see the wires if you look from door into the fender well opening. I also think if you take the bottom of the glove box out (2 screws) their is a relay center that contains power ant. relay. |
Re: Power Antenna
I have looked all over in this area and never found it, I can see the wires through the door jam behind the fender, but I need to disconnect the ele. connector and antenna. I will check this again.
Re: Power Antenna
I have the same problem! The antenna cable is NOT visible behind the "kick panel" nor is it behind the "Glove Box". If anyone has actually found it
on a 94 ZJ, I would like to know! Hayes manuals are useless. |
