Go Back   Automotive Forums Car Chat > Honda > Legend | RL
Old 02-04-2005, 03:06 PM
mkhan mkhan is offline
Unhappy 96 rl steering/handling
Hi guys ! i am new to this forum, my acura 96 RL steering wheel doesn't response smoothly/efficiently car has 150000+ mileage. i am wondering if it has anything to do with power steering pump? and if it does where should i get one for cheap? any advice is appreciated. thanks
Old 02-04-2005, 04:48 PM
phantastic1 phantastic1 is offline
Re: 96 rl steering/handling
first check if p/s fluid is filled up. if not...fill it back up and test drive. also...if it wasn't filled up...my be an indication that you may have a leak. if fluid level is ok...check tire pressure. if tire pressure is low...it could give you symptoms your describing. front wheel alignment may be a factor as well.
Old 02-16-2005, 08:09 PM
nbr1nthuzyst nbr1nthuzyst is offline
Send a message via AIM to nbr1nthuzyst Send a message via Yahoo to nbr1nthuzyst
Ive had the same problem occur on my moms 96 Rl, with 136k miles. It doesnt happen all the time though... it has only happened maybe 3 times *at most* but i dont know where its coming from... i guess all i can say is check the fluid and maybe the leak... but i know for sure my mom'd doesnt have those problems (weve had it inspected)~but we were told nuthing was wrong~ hope it helps
