Old 02-04-2005, 02:59 PM
jbizel's Avatar
jbizel jbizel is offline
hot air intake.
i have a hot air intake. the one that just goes in place of the stock air box. is there any way i can make that a cold air intake???? or what are some good suggestions? thanks
Old 02-04-2005, 04:19 PM
stlwagon stlwagon is offline
Re: hot air intake.
What do you mean? Do you have an open cone setup? If you have a box that draws air from behind the headlight/fenderwell, then you have a cold air intake.
Old 02-04-2005, 04:29 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Sounds as if he has something like this
ClubGP Member 6530
Since 2001
Old 02-04-2005, 04:45 PM
bcreverend's Avatar
bcreverend bcreverend is offline
Re: hot air intake.
you could build a box for it possibly, to shield the cone from the engine heat and draw from behind the headlight and the fender...i've considered doing this myself using stuff from a hardware store but i just haven't had the time to put into it.
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 02-04-2005, 10:08 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: hot air intake.
I've got a hot air (warm air intake - WAI) setup on my Grand Am. I like it better then a CAI due to it's better off the line response, but I succesfully routed 2 lines, one from the wheel well, and one from the front air damn up to the filter. They are against the filter, so they help to suck in colder air when I get up to speed. So mine's kind of a WAI/CAI hybrid setup. I would reccomend running cold air lines to your cone filter - I noticed a little bit of a difference on the top end.
Old 02-04-2005, 10:42 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: hot air intake.
I was just going to say hello to wagon and Big-L. BUT, I have to ask why you think that set up is better then a cold air box? Cold air box is enclosed, getting air from the outside. Yours is still sucking hot air from under the hood. OH WELL.
Larry,
Your old enough (ha ha) to remember the "ice buckets" from the 60's. Where they had a coil in a "bucket". And they would fill it ice, to keep the gas cooler. Maybe still a good thought. How long do you think the gas will last down here?
Old 02-05-2005, 12:24 AM
Melvyn_with_a_GTP Melvyn_with_a_GTP is offline
yeah. just make one yourself. You already have the filter(the main part) For mine i went down to lowes and picked up some insilation (fire retardant kind with a silver look) and some aluminum tape and just constructed a boc around the cone that meshed up around the holes behind the headlight and the fenderwell. Made a good difference over my hot air open cone. It was easy and quick to do to boot.
Old 02-05-2005, 09:47 AM
BIG-L's Avatar
Larry,
I had one on my car back in 73,when I had a 69 Z/28.They where called Cool Can's.I'd go to a place called the Ice House on firday and buy some dry ice and put in it.They might work well for an IC,for the drag strip.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-05-2005, 02:51 PM
Ridenour's Avatar
GranddAmnit
Re: Re: Re: hot air intake.
Originally Posted by kustomkid54
...I have to ask why you think that set up is better then a cold air box? Cold air box is enclosed, getting air from the outside. Yours is still sucking hot air from under the hood....
Well it's really up to the preference of the driver. WAI's beat CAI's off the line, due to the lag of the CAI having to suck the air up that long tube. There's a couple reasons really, but I prefer the WAI, and my setup combines the best of both worlds - pipe length of WAI and I've done enough stuff to increase cool air flow to that area to give it pretty much the coolness of CAI after I start moving. It is really up to the driver though. Me and some other guys discussed the pro's and con's of both thoroughly in this thread:
http://www.automotiveforums.com/vbul...d.php?t=334145
It's pretty interesting to read.
(BTW: the pics in the thread of my intake are old - my intake's different now and has 'cold air lines' running up to it)
Old 02-05-2005, 03:30 PM
BIG-L's Avatar
Sorry,but our GP's are different then the GA's and we dont have a long intake tube,plus at the strip we can remove the headlight for increased air flow
Picture of an MSP CAI
ClubGP Member 6530
Since 2001
Old 02-05-2005, 08:33 PM
Re: hot air intake.
That's the reply I was looking for.
Old 02-05-2005, 08:34 PM
Re: hot air intake.
I'll have to get a hold of my Brother-in-Law. He has one out in the poll barn. See if he'll send it to me. Let you know.
~Larry~
Old 02-06-2005, 09:47 AM
leadfootGTP's Avatar
leadfootGTP leadfootGTP is offline
Re: hot air intake.
the only real advantage to a "WAI" (i think it is actualy called a SRI for short ram intake, but thats not a term ive heard too often so i dont know) is that the pipe is shorter so there is less hesitation before the air gets to the engine. In grand prixs though the cool air setups such as the MSP or Wizaired are already so close to the cool air that they use, that it really doesnt make a difference. In any case, warmer air is much less dense than cold air which means tha there are a lot more oxygen molecules in a given amount of cold air than in warm, more oxygen can burn more gas, which brings more power.
[IMG][/IMG]
