Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-04-2005, 02:22 PM
Jettaguy101 Jettaguy101 is offline
Keyless remote programming for 2001 Jetta
PLEASE if any one can tell me how to program the remote. The batterys had run down for a long time when I replaced them it did not work how could I reprogam the remote?
Old 02-04-2005, 05:29 PM
jcc6655 jcc6655 is offline
There are instructions in the handbook that comes with the car section3.1 page 37 here is what it says
insert the master key into the ignition lock and switch on the ignition (do not turn on engine)
Lock the vehicle from the outside manually using the second key
press button a or button c on the remote control one time and then wait at least 2 seconds
press either button once again one more time
switch off the ignition and remove the key from the igntion lock
the manual programming procedure is complete the remote control is functional again
also you have only 30 seconds to perform steps 2 through 4
hope that helps
