Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-04-2005, 01:12 PM
laneyboy6933 laneyboy6933 is offline
engine problem
I am just starting to rebuild my 1973 302 and i just started to tear it down slowly. I toke the timing cover off and to my surprise the cam had moved foward and was driven like that and it ate into the cover. To prevent this from happening when i'm done what can i do? I also realized the timing chain had a crap load of slop in it. What Do i do?
Old 02-09-2005, 01:00 PM
Re: engine problem
Can anyone suggest a part that i can get?
Old 02-11-2005, 12:14 AM
benchtest benchtest is offline
Re: engine problem
What happened to the cam thrust plate?
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 02-11-2005, 01:24 PM
Re: Re: engine problem
It's there, didnt seem to be damaged.
Old 02-13-2005, 10:30 PM
Re: engine problem
1) Was the thrust plate bolted down? (sorry for the dumb question..but gotta ask) 2) Around '72 Ford changed the thickness of the cam gear. A '73 should be the thicker gear, which with '73 parts should not contact the cover. However, if the motor is a '72 and the parts are intermixed, you may get contact. You'll need to investigate to be sure. Hope that helps.
