Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 02-04-2005, 01:21 PM   #1
reptileis
Question 95 740 Il Sunroof Drainage Issue
To anyone that may have had this issue:
My 95 740 has a leak on the passenger side, upper A piller. It comes in just above the windshield- (so i can rule out a faulty seal there)- and it would have to travel uphill from the door seals- which leaves only the sunroof as the cause.
I opened the sunroof looking for a clogged drain tube, and found that the forward drain holes are puttied closed on both the driver and passenger sides. the putty may be not making a seal anymore on the side that leaks, but before I re apply anything- I wonder what the problems may be if i seal it off.
I believe that water is getting past the putty, traveling down the drain tube which must be missing or damaged causing the water to enter car at the a piller. has anyone replacedc one of these tubes before? is the process fairly simplistic? or should i just try to putty it closed again forcing the water to drain at the rear tubes.
your thoughts on the matter greatly appreciated.
MB
reptileis is offline   Reply With Quote
Old 02-04-2005, 09:28 PM   #2
ibew595
ibew595's Avatar
Send a message via AIM to ibew595
Re: 95 740 Il Sunroof Drainage Issue
It sounds like clogged drain tubes. Does that putty look like it is OEM? Has the windshield ever been replaced? If it has they may have screwed up the drain tubes which run down the A pillars.
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
ibew595 is offline   Reply With Quote
