cricket noise
the cricket chirps around the cylinders, I think. the chirp is usually constant and only when the engine idles. It's definately coming from the middle top left of the bay.
Will |
Re: cricket noise
Either the idler pully, worn belt, or the ac bearing...Use a wooden dowel like a stethescope and you will be able to track it down.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Rplace your throttle body base gasket.
Easy to check.
Base gaskets burn out, only cost $5 With engine running spray carb cleaner moderately at base of throttle body, your idle will pickup and chirp will go away momentarily. Last edited by MAS904; 02-20-2005 at 02:37 PM. |
