Old 02-04-2005, 11:11 AM
Ascot Ascot is offline
Power Window
About a year and a half ago, I replaced the power window master switch on the drivers side (bought the part from the Pontiac dealership). The symptom was that the speed of the window kept decreasing until it no longer worked, when I pushed the button for the driver's side window. However, the rest of the windows worked fine from the master control.
The same problem has re-occurred and I am looking for some help to diagnose the problem. I am thinking that the motor needs to be replaced. When I called up a junk yard to order a used part, they asked me if the regulator was also shot.
How can I test both parts to see if the are burned out. Or if it's a re-occurrance of the master switch problem.
Many Thanks,
Ascot
Old 02-04-2005, 01:24 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Power Window
Your window adjustments screws may be too tight causing the motors to burn themselves out. It is most likely its just the motor. Regulators do go on occassion but 9 times out of 10 its just motor shorted out from overheating. Also you may be better off buying a rebuilt unit since your having a problem I think its autozone that guarantee's there window motors for like 3 years or something. Good Luck.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
