engine noise
Can anyone explain the cricket in my engine? When in idle my engine squeeks. Sometimes it sounds like a cricket chatter.
Re: engine noise
Mike |
Re: Re: engine noise
The cricket in my engine seems to be coming from the cylinder area. Looking at the engine from the front, it's to the left of the top of the middle of the bay. Make sense?
Re: Re: Re: engine noise
What year and what engine to you have? Nothing pops out as to what the noise may be. The better you can isolate it... find out where it's coming from... the better the chances of finding what's squeaking. |
Re: engine noise
Your belt, or your idler pulley or your alternator?
mine used to make that type of noise to.. i gave one squirt of wd-40 on the belt from the area it was coming from and it fixed it.. but my belt was comin close to replacement time..
Re: engine noise
1995 Factory Blazer Service Manual for sale, PM if interested. |
1 was cured by adjusting screw on left of carb bottom, i 4get what haynes book said it was, either mixture or idle. other noise i thought may be alternator, or water pump, or steering pump or ac compressor. i discovered it to be the ac clutch assembly by spraying oil in it with it running. with off i drop engine or diff oil, say a spoonful on that seem on top to let it settle in. loosened off belts that were bit tight to spare bearings on other pullys. no more noise. bar soap on slipping squeeking belt has worked til i adjusted tension or replaced with new. tiny hole under center of water pump shaft will leak when that seal and bearing is going. not mine yet. spraying little light oil may help find area of squeek. or metal or wood bar apllied to varios spots and your ear to see where loudest. |
Re: engine noise
I'm think this problem is from the alternator or water pump bearing wearing out and dry.
Re: engine noise
moderately spray the base of throttle body while running engine with carb cleaner. Idle will increase and cricket will shut up momentarily. Last edited by MAS904; 02-20-2005 at 01:38 PM. |
Re: engine noise
TB gaskets don't cause squeaks, they cause a hissing noise.
gasket was burned out under the throttle linkage. Also caused a little bit of a high idle due to air bypassing the closed throttle plate |
