Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-04-2005, 03:23 AM
BUGDUST BUGDUST is offline
Baaad Noise 93 Jgc
Recently Started Having Problems With 4.0 93' Jgc. Fuel Pump Is Most Likely In Need Of Replacing. Pressure Is Right Around 20-25 Throughout Acceleration. Will Hesitate Badly And Stall At Times. More Concerning Is Very Loud Rumble/rattling Noise At Bottom Of Engine While Running And Hesitating, Until Engine Catches Up And Runs Smooth
Old 02-04-2005, 10:38 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Baaad Noise 93 Jgc
I think the hesitation/stalling problem, could possibly be a bad Throttle Position Sensor.
Old 02-12-2005, 10:50 AM
Re: Re: Baaad Noise 93 Jgc
THANKS FOR THE SUGGESTION. I HAVENT CHECKED THE TPS YET, BUT SUSPECTED THE FUEL PUMP AND PUT A GUAGE ON IT. IT READ AROUND 20-24 MAX, UNDER ACCELERATION THE READING USUALLY DROPPED. SRTRTING SEARCH FOR FUEL PUMP, 1993 JGC 4.0 CANADIAN. CALLED LOCALLY AND WAS TOLD THAT CANADIAN VERSION WAS DIFFERENT THAN AMERICAN. ANY IDEAS? THE LOUD NOISE TURNED OUT TO BE THE BOLTS HOLDING THE CONVERTER TO THE FLYWHEEL WERE LOOSE. I WILL ALSO CHECK THE TPS, JUST TO BE SAFE.
Old 02-12-2005, 11:00 AM
the low fuel pressure, could be contributed by a bad TPS as well, or clogged Fuel Filter. may want to replace (if not done so recently) the Fuel Filter. Cheap easy and should boost your mileage a lil.
Old 02-13-2005, 06:02 AM
Cam7 Cam7 is offline
Fuel presure is 20 lbs to low. Most probally bad pump. Never heard of Canadian being Different. Probally have to remove the pump and match it to a new one if the Canadian version is really different. My 93 XJ 4.0 has a Bosh as orignial part. Not sure about ZJ of that year.
Old 02-17-2005, 07:00 PM
with the exception of checking pressure at the fuel rail is there another way of checking fuel pump? is there a certain volume the pump should put out per min. ? if i were to wire the pump direct just to check volume without involving the tps or any other part of the system, just pump output
Old 02-17-2005, 11:41 PM
I dunno, I am not sure what the GPH (gallons per hour) is on the OEM fuel pump.
