Old 02-04-2005, 12:37 AM
2crunk's Avatar
2crunk 2crunk is offline
Flashlight?
In my '87 GT that i just purchased i have a question about a flashlight looking object on the headliner of the car. I dont think it works, at least i can't seem to get it to come on, but my domelight works fine. Does it have something to do with the domelight or is this an aftermarket item somebody stuck in there?
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 02-04-2005, 01:43 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Maplight im guessing
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-04-2005, 06:11 AM
b3warnick b3warnick is offline
It's a maplight.
Bulb may be burned out.
Also if not tightened up just right, the connection won't be complete and it won't work. It's just held in with 2 screws...take 'em out and you can remove the whole thing. The very end of the 'flashlight' unscrews and you can access the bulb.
You can pick 'em up cheap at a junkyard. Ford also put the same thing in Taurus'. Probably some other Ford's as well.
Handy little item to have around (esp. at night when you can't read your digital clock or radio station on your original radio since he hasn't lit up for the last 10 or 12 years )
Old 02-04-2005, 11:17 AM
2crunk's Avatar
Re: Flashlight?
Cool, thanx for the info.
Old 02-14-2005, 06:56 AM
joe4speed joe4speed is offline
Send a message via ICQ to joe4speed Send a message via AIM to joe4speed
Re: Flashlight?
Also try flicking the switch (little round button where the light snaps in) if it's not the bulb.
