Old 02-03-2005, 11:20 PM
BassLizzard BassLizzard is offline
1994 S10 4.3 Liter Fuel Pump Staying on after ignition turned off
I have to pull the fuse to get the fuel pump to stay off could someone please tell me where the Fuel Pump Relay is on my truck I have the owners Manual and it's no help.
Old 02-04-2005, 12:04 AM
jm1 jm1 is offline
Re: 1994 S10 4.3 Liter Fuel Pump Staying on after ignition turned off
I have a 93 as well and the relay is in the engine compartment (drivers side) next to the master cylinder; should be the the left of it. Its a little black square box. That's all I can tell you, but I really dont know if thats the problem. Usually the thing goes out and the pump wont start but not the way it works for you. Good Luck!
Old 02-04-2005, 02:07 AM
hakogen's Avatar
hakogen hakogen is offline
maybe a bad ground someplace. try the relay first, if that doesnt work, get a tester and happy hunting
Old 02-04-2005, 02:31 AM
I also tried replacing the ignition switch and that did no good I looked near the master cylinder and didn't see any relays is it under a cover?
Old 02-04-2005, 02:43 AM
hakogen's Avatar
it might be in the fuse block, or it might be on a framerail near the ass-end of the truck. honestly, i just dont know.
Old 02-04-2005, 04:32 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
its mounted on the firewall all the way to the upper right hand corner of the engine compartment.
Old 02-04-2005, 11:05 PM
driver side or passenger side? I just don't see it.
Old 02-05-2005, 08:12 PM
jackass#1's Avatar
drivers side. in the corner behind mastercylinder and to the right on the firewall. its a black rectanglar cube
shaped maybe 2 of them side by side.
