Old 02-03-2005, 09:01 PM
91rscamaro 91rscamaro is offline
Send a message via AIM to 91rscamaro Send a message via MSN to 91rscamaro
whats better, a LT1, LS1, 350 HO or 383
which one would be the best bang for the buck. i want lots of power and it to be quick. i also would like one with the easiest mods to make, and if it will fit in a 91 rs camaro.
Old 02-03-2005, 09:29 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: whats better, a LT1, LS1, 350 HO or 383
What do you have in there right now?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-03-2005, 09:32 PM
Re: Re: whats better, a LT1, LS1, 350 HO or 383
lol a v-6, not quick at allll
Old 02-03-2005, 09:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
I would go with a 350 TPI or LT1 cause the LS1 will cost you your first born but just check out www.car-parts.com or Ebay. I am sure you will be able to find something. Don't forget about tranny and PCM.
Old 02-03-2005, 09:40 PM
can u shoot me some ideas or a tranny and PCM? i am also going to be taking an engine rebuild class and i will be bale to rebuild a used one, u thinki could get a pretty cheap one and rebuild it with all the upgraded parts like heads and cam and all that stuff. and do u know price ranges for used LT1s or 350's?
Old 02-03-2005, 10:09 PM
LT1MAN LT1MAN is offline
Banned
LT1's are definately the best
Old 02-03-2005, 10:12 PM
82KnightRider's Avatar
82KnightRider 82KnightRider is offline
LG4 is the best...........j/k
Old 02-03-2005, 10:37 PM
so what do u guys think, LT1 or 350 TPI?
Old 02-03-2005, 10:40 PM
FormulaLT1's Avatar
Fight the powwa!!!
Both are great power to cost engine but I would try to find a donor car cause your probably going to be needing quite a few parts off the car. Infact tho. Depending what area your in I know lotus is selling his car that was in a accident for 2K and its the complete car. He located in CT though. Its a LT1 with a 6 speed I think may have a auto
John
Old 02-03-2005, 11:04 PM
John
alright, thanks a lot. i dunno where CT is, im prolly just being dumb, but i live in MN, so maybe i can go to a slavage yard or somthing and pick somthing up. that sounds like a sweet deal tho.
Old 02-04-2005, 12:32 AM
Morley Morley is offline
An easier route, and easier to mod, would be a 350 with an Lt1 intake running off the TPI harness and ECM. This would get you the best of both worlds, the desireable LT1 intake system and the easy to program ECM/chips. I work with a guy that sells the LT1 intakes already modded for use on the standard 350 engine, he also sells the complete set up for installing it.
His web site is here: http://lt1intake.com/services.htm
Old 02-04-2005, 11:33 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
i figured this one would spark more of a debate. in terms of sheer efficiency and power potential: the LS1 cant be beat. im sorry LT1 guys but you have to face facts, the LS1 is the greatest SB development prolly ever. in terms of cost to build up and other more real world factors prolly the LT1...
*Better power-to-weight ratio than a C6 corvette*
Old 02-04-2005, 12:32 PM
FormulaLT1's Avatar
Fight the powwa!!!
Was that a joke at the LT1 & TPI guys expense and I just missed it?. Well I will respond regardless. LS1 is the N/A king. It can make the most power with the smallest investment. Having said this the cost of getting a LS1 Vs getting a LT1 or TPI powertrain or better yet getting it to fit correctly in a 3rd Gen Vs the performance difference you will find that the LS1 just isn't a wise choice and if later on he decides he wants to add a power adder the LS1 is much more PSI limited than either of the 2 options but this is just my , Take it as you will.
John
Old 02-04-2005, 02:16 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Im gonna go ahead and choose the lesser traveled path Take your 350TPI and stroke it to a 383.. With the right parts, and you doing the work, it should cost less than the LT1 swap, be less work, and make more power
1991 Camaro Z28
Old 02-04-2005, 04:38 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
That would be badass. I always see carb'd 383's, and injected 350 TPI's(obviously, its TPI), but I have never seen a 383 with TPI. It should be fairly inexpensive, and fairly unique...now I want one!
