Old 02-03-2005, 08:10 PM
silveradoking silveradoking is offline
throttle body by- pass mod
has anyone tried the throttle body by-pass mod? it is supposed to make the air more cooler in turn better performance......???????????
Old 02-03-2005, 10:27 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Re: throttle body by- pass mod
I've done it. I don't know if it helped anything or not, but I just don't like the fact that warm air is running through my throttlebody warming the air up, when my local temps are always fairly warm. Hey, it was cheap and easy, so why not.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 02-03-2005, 10:35 PM
silveradoman silveradoman is offline
How do you do one of those thing-o-majigs?
Old 02-04-2005, 03:26 PM
yankeeintruder yankeeintruder is offline
The throttle body has two hoses connected to it.... in the front, underneath. They carry coolant through from the radiator thusly heating the air coming through the throttle body for better idleing and quicker warm-up in cold weather (supposedly).
Anyways...... disconnect both hoses and connect them together. You'll need a couple of hose clamps....... about a foot of hose (cut to suit) and a hose coupler. I beleive the size is 1/4"' I.D. (It's been so long since I did this mod...... if I'm wrong on the sizing maybe someone else can verify).
I had two choices on the hose coupler... a plastic one and a brass one. I chose the brass....... has two barb rings around the ends so when you push it into the hose it kinda tough to pull back off.
I also plugged the two open ends on my throtle body with a couple of rubber caps held on with hose clamps.
Cost about $5-$6 at the parts store. Good luck!
Old 02-04-2005, 06:38 PM
Thanks for the info, its simple enough. I just have one question, does this mod affect the way the truck goes into a closed loop, you know for emissions?
Old 02-04-2005, 08:44 PM
Re: Re: throttle body by- pass mod
You'll be ok with this mod. It's just to help warm the truck up on cold days.
Old 02-04-2005, 09:42 PM
so then...
so then this mod is supposed to be an advantage? sorry, guys i am a little slow..... does doing this mod give you quicker warm up time in cold weather or leaving as it is, give you better warm up time? if this is so then why would you do it.... does it give you that much of a performance improvement?
Old 02-04-2005, 10:19 PM
Re: so then...
The original design of the line going into the throttle body gives you quicker warmup. Doing the mod will make it take a little longer to warm up. I couldn't tell a seat of the pants difference in doing the mod, but like I said earlier, I just don't like the fact that warm/hot coolant is going into my throttle body warming up the air.
Old 02-04-2005, 11:11 PM
I like it, I live in the desert so I donīt need the air hotter than it usually gets, Iīm definetly doing it.
Old 02-04-2005, 11:50 PM
Living in the desert!!........ no hesitation. I live in PA. and I really don't notice any difference in warm up or in throttle response. But like slowprocess, I didn't like the idea of the air being warmed when everybody knows cooler air is better.
Guess I'm old school.
Old 02-05-2005, 09:00 PM
huh?
I still don't know what to do.... do you guys think I should do it....? I live here in Toronto, Canada.... it gets about minus -37 degrees celcius weather up here... burr....well at least it was a couple of weeks ago.....can anyone say co-co-cold....
Old 02-06-2005, 12:16 AM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
What if the metal of the throttle body gets hotter than the coolant from the intake temp. They the coolant would be COOLING the throttle body right? How hot does the TB get in hot weather. Has anyone tested it?
2001 Silverado
Crew Cab 2500 HD - 8.1 - Allison
6" RCD Lift with 35" BFG Mud Terrains
Airaid Intake - 4" Magnaflow Exhaust - Hypertech Programmer
Old 02-07-2005, 07:00 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I don't think it gets to 210...I did my mod when my truck was still farely warm from driving and it was cool.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
