Old 02-03-2005, 07:36 PM
Nick731 Nick731 is offline
Question 1997 3000GT VR4 engine coolant problem
HI everybody,
I own a 1997 Mitsubishi 3000GT VR4.The car it’s just unbelievable and I love it, but in the last year I have been dealing with reoccurring problem. I am loosing engine coolant. The car has been in the dealership at least 4 times. They pressurized the system and there aren’t any leaks or faulty gaskets. They changed the radiator cap & thermostat every time but without success. Everything is normal for a week or two and than I have to add coolant every other day. Basically a lot of the coolant is getting transferred in to the overflow tank (and leaking on the ground from there) leaving the radiator half empty
I would appreciate any helpful advice or even an address of a good mechanic in the Detroit Metro area.
Thank you very much, Nick731
Old 02-08-2005, 10:40 PM
unicyclemidget11 unicyclemidget11 is offline
i have the same problem with my 93 vr4. I add coolant one day and a week later i start seeing it in the driveway.
Old 02-09-2005, 11:30 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Re: 1997 3000GT VR4 engine coolant problem
thats sorta weird... are you sure its going into the overflow tank?... usely it goes into the overflow because its too full. but then if its running low it should suck it back out of the overflow back into the thermostat houseing... there could be a clog or a bad thermostat cuaseing it to flow into the overflow... but that would cause it to over heat very badly. Did you try the water pump? the water pump might be working but leaking or all together not working or going bad... uselly at a 60K and 120K tune ups they will change the water pump and all the belts and what not... so if your geting close to 60K you might try that.
Upgrades... To many to list...
Old 02-09-2005, 01:54 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Hey i have that same problem with my 94 SL...leaks into the overflow tank and onto the ground...every other week my little light comes on to add coolant....and had my water pump timing belt done about 10k ago. I wonder if it's just the nature of the car?
Old 02-09-2005, 04:55 PM
azn3000GTRacer azn3000GTRacer is offline
LOL i have the same problem to and i have a 96 VR4 but i have an extra problem, my fan wont turn on unless i have the air conditioning on. The fan wont kick in when the engine starts to run hot and i always overflow colant but when i have the air on i usually dont lose colant though.
Old 02-09-2005, 05:53 PM
92VR4Red's Avatar
Hmm the check the relays... mabey the fans relay went out or the sensor...
Old 02-09-2005, 05:57 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
well guys, i have the same problem also
what to do?
Old 02-09-2005, 06:16 PM
Igovert500's Avatar
blue + red light magnet
http://www.3si.org/forum/showthread.php?t=254437
http://www.3si.org/forum/showthread....7&page=1&pp=10
http://www.3si.org/forum/showthread.php?t=249782
These have a bunch of suggestions...check em out
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-09-2005, 06:36 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
That is really strange that you all have the same problem, ive never had that problem before, thats really strange. could a there be air in the system that would cause it to push coolant out as it expands with heat?
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 02-09-2005, 11:32 PM
well dude had his system pressurized a few times he said and to no avail...I think we need a recall!!
Old 02-10-2005, 12:21 AM
3KSL95's Avatar
Thats what im thinkin.
My mods:
K&N FIPK
Old 02-10-2005, 11:54 AM
Igovert500's Avatar
Well don't be so quick to jump to conclusions...the first poster described his problem...and the troubleshooting he has done...
Nobody else said they even tried replacing the t-stat or radiator cap...so don't all assume you are having the exact same problem. His problem may be a bit more complex, while many of you may be able to fix yours for under $50.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
