Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-03-2005, 07:25 PM
wine wine is offline
Question drive belt replacement
My 97 Sentra has power steering and air condition and automatic.
I need to know which bolts need to be loosened (where they are located) to install be alt/ac belt and power steer belt. This be most painful belt to replaced of the cars I've owned. Pictures would be great. Please help guys.
Old 02-04-2005, 08:44 PM
watleyap watleyap is offline
lol
well i have done it like 3 times now b/c i have bad luck. but for the alt/ac belt u need and 8mm socket and just above and behind the compressor u will find the bolt off a long threaded shaft. as for the ps/wp belt it is kinda tricky, u have to losen the ps pump from behind it and then with a 12mm there is a bolt sitting on the edge of a bracket facing the firewall and down by about 15-20 degrees just losen it up and u that should do it. not sure if that will be the same for u but i know for the GA16DE thats where they are, atleast in the 99 gxe le. hope that helps u.
Old 02-06-2005, 08:51 AM
reply to help
I remove the water pump pulley to remove the belt. Those p/s are very difficult to remove. Do you know how many alternator bolts (location) do i have to remove to release belt tension? Thanks.
Old 02-07-2005, 04:15 PM
hmmmmm not sure if ur motor is diffrent or not b/c my alt is in a fixed mount. so i have to release the tensioner b4 i can pull any of the alt bolts without damaging the alt. i would have to suggest u go to the local parts store and get the hanyes manual, they are only like $15 and will tell u how to do it all
Old 11-02-2008, 03:03 PM
NightmareSS NightmareSS is offline
Re: drive belt replacement
I have the same question as Wine does. As for the Haynes Manual it doesn't tellyou jack about (HOW?) to replace the belts. Ifanyone has a more informative way to go about this please let me know. Until then my everyday ride is out of commission...
2005 Chevy Cobalt SS/SC STG 2 - 1998 Nissan Sentra XE (Daily Driver)
