Old 02-03-2005, 07:36 PM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Heater
My truck wont blow hot air. i left it warm up for 10 mins, and still no hot air whats wrong.
Old 02-03-2005, 08:03 PM
jsgold jsgold is offline
Several possibilities. Themostat stuck open, clogged heater core, or vacuum leak causing the heater door to stay closed. Could be any of these, including low coolant in radiator.
Old 02-03-2005, 09:38 PM
hakogen's Avatar
hakogen hakogen is offline
what year is the truck and what kind of thermostat do you ahve?
i bought a failsafe from autozone, and it locked open on my '01. took me like a week to think to check the thermostat. lo and behold, it was just that.
Old 02-03-2005, 09:42 PM
91S10's Avatar
Its a 91, and its just the stock thermostat so we it is idk.
Old 02-03-2005, 09:48 PM
hakogen's Avatar
go to your local parts store and buy a plain jane thermostat and slap it in. the stat and gasket should cost less than 10 bucks and you can change it in about a half hour. this is where you should start.
Old 02-03-2005, 09:51 PM
hakogen's Avatar
crap i forgot to mention:
if you ahve an actual temp guage in the dash, it should be up around 180. otherwise it might not be the stat. if its down aroun 100 - 120 its prob the thermostat
Old 02-03-2005, 11:46 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Heater
ive got a vacume leak and not saying its the same for all vehicals, but my 98 has a vl and its stuck open, hot as hell in the summer time
Old 02-04-2005, 03:15 AM
hakogen's Avatar
Re: Heater
you need one of those busdriver type mini fans, brisket. hehehe.
Old 02-04-2005, 07:19 AM
Re: Re: Heater
lol, my girlfriends grandpa has the same exact truck, and one day we finaly said Fu*k this and put ball valves on the heater intake, let it flush through every now and again in the summer
Old 02-04-2005, 01:46 PM
91S10's Avatar
My temp gauge is stuck at 100, it wont move from that. Probably next week ill pick up the thermostat and stuff, b/c i dont get paid till then and i dont drive it that much either so ill change it later. Thanks
Old 02-04-2005, 02:07 PM
hakogen's Avatar
Re: Heater
thats most definately the thermostat locked open. dont forget the gasket. good luck!
Old 02-04-2005, 04:25 PM
sector95 sector95 is offline
Re: Heater
Changing the t-stat for the engine *probably* won't fix your problem. I mean even if you have no thermostat, the coolant will eventually get hot and, unless you're driving around in sub-zero temps, there will be some heat coming out of the heater.
I have an '85 S10 and I had a '93 S10 and they both use vacuum motors to control valves (or doors) in the HVAC plenum under the dash; if this were my truck, that where I'd focus my attention. My guess is one of these vacuum motors has gone bad (has a leak) or one (or more) of the vacuum lines is leaking or fallen off. You don't say what year your truck is (a '91 maybe?). On the older style (pre '93) S-10's there is a main vacuum connection to the Heat/Vent/AC dash control panel; the panel has a multifunction valve that routes vacuum to the selected motors depending on what you've selected...that valve could be broken or leaking. The source of the vacuum is from the engine intake mainfold and you may have to do a little searching to find where it ties in.
Are there any other selctions/functions (defrost, vent, etc) that don't work?
Go ahead and change the t-stat, but I think you'll find it won't solve your problem....
...just my humble 2 cents.
Mike
Old 02-06-2005, 12:35 PM
gijim19 gijim19 is offline
suggestion: If the thermostat doesn't help the problem, check the heater core. The easiest way to do this is to check the passenger compartment for water on the flooorboar. Also, when the core cracks anti-freeze is blown out the vents and fogs up your windows from the inside. If any of this shows, I suggest going to a shop and letting them struggle with it. It's a job and a half to change the core. These are just a couple of humble suggestions. Oh yeah. If you should see a leak at the fitting going into the block, go gentle on it. I broke the fitting off inside the block and had to take the whole intake manifold off to re-tap the hole. oops
Old 02-06-2005, 12:43 PM
Re: Heater
gijm19, that must have really sucked, funny as hell from where im sitten, but that must have taken hours
Old 02-06-2005, 01:10 PM
91S10's Avatar
Sometimes there is a big puddle in the passenger seat floor. i figured i had a leak somewhere, but i guess its that
