Old 02-03-2005, 06:05 PM
comp comp is offline
Oil smell
daughter's 3.8 " smell's of burnt oil " sometime's" is there a normal thing to check for on these ????? Oh it is in the car with the heat and or defrost on,,, the rad. fan cycling is one thing i have thought of
Old 02-03-2005, 06:14 PM
auto trainy auto trainy is offline
Re: Oil smell
It just might be dripping oil on the back exaust manifold where you can't see it,not that uncommon,it doesn't take too much and is burnt away quickly.
Old 02-03-2005, 06:19 PM
valve cover gasket ??? can i see with a mirror ???
Old 02-03-2005, 06:33 PM
Re: Oil smell
That would work but also look for oil leaking from the upper manifold and working its way along the valve cover and making you think its a valve cover gasket. Good Luck
Old 02-03-2005, 06:38 PM
i was hoping not to hear that one any where else to check ??
Old 02-03-2005, 11:40 PM
i will check ....
Old 02-06-2005, 09:46 AM
AUTO, you are correct , intake leak she is going to be getting her tax check soon so let me know best/easiest fix and other things to check/replace etc. while i'm working on it. Also what is the best book on that engine ??? i'd like to not have to drop$$$$ on a factory book. Thanks now
Old 02-06-2005, 10:07 AM
Re: Oil smell
I have two Olds a 95?98 and both have a slight seepage,I wish I could tell you exactly what's involved,but have not had the pleasure of doing one myself but if you check through the Olds,Buick,Pontiac 3.8 v6 forums you'll find what your looking for.I have asked about a Ken-Co kit on the forum but have no response as to where to purchase one or whats in the the kit. Good Luck
Old 02-07-2005, 08:02 PM
Thanks , maybr someone else will see this and chime in
Old 02-09-2005, 10:45 AM
nobody has a good engine book but the Factory GM one
