Old 02-03-2005, 05:46 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
Is this normal
I just had a new clutch and flywheel installed and when i first fot it back the clutch felt ultra light (much to my dismay) its been about a week and its abeginning to stiffen up like the old one is this normal?
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 02-03-2005, 06:01 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Is this normal
Light as in easy to push the pedal down?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-03-2005, 06:10 PM
3KSL95's Avatar
Re: Is this normal
yea sorry for the miscomunication.
My mods:
K&N FIPK
Old 02-03-2005, 06:27 PM
3KSL95's Avatar
Re: Is this normal
Hey
My mods:
K&N FIPK
Old 02-03-2005, 06:35 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Is this normal
Doesn't sound like the clutch is the problem...that would be you clutch slave cylinder if you're noticing a difference in how hard it is to push the pedal down. Check the level of the fluid and the color, if it's black or really dark it needs replacing.
Old 02-03-2005, 06:37 PM
3KSL95's Avatar
Re: Is this normal
Its just strange when i had the old clutch it was stiff, when i drove away with the new one it was REALLY and i mean really light, but now its like the old one was.
My mods:
K&N FIPK
Old 02-03-2005, 06:43 PM
G35turbo G35turbo is offline
Re: Is this normal
Did u do u r own clutch. If not they probably dident flush the clutch lines.
Old 02-03-2005, 06:57 PM
3KSL95's Avatar
Re: Is this normal
No i had it done at a dealership, it functions great its just gotten stiffer. Its just like it used to be.
My mods:
K&N FIPK
Old 02-03-2005, 07:52 PM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Re: Is this normal
hmm if the clutch is functioning properly than I wouldn't give it a second thought.
Old 02-03-2005, 08:33 PM
hmmm, that's kind of odd...the only thing that I can think of that effects the stiffness of the pedal would be the slave cylinder and the clutch (brake) fluid. I think you're supposed to adjust the clutch pedal freeplay after a new clutch is put in after a certain amount of miles with some cars, but I don't know about this one. But if everything works good and the clutch is new then you shouldn't have too much to worry about. I had a similar problem with an Integra I owned...after a few hundred miles the pedal felt like it did right before the old clutch went bad...but it's still lasting w/ the new clutch today and that was 3 years ago and about 40k, so I wouldn't worry about it.
Old 02-04-2005, 01:17 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Is this normal
noobs! haha, jk. no, this IS normal, so don't worry bout it. when i had my clutch replaced, i drove it around then came back and asked them why it feels differently. they said its common and happens on every car. it is so becuase when you change the clutch, at first it will engage like its supposed to! you might have felt like the clutch engaged a lot earlier than it would have normally. this is what i experienced at least. i only had to press the clutch pedal halfway in to engage/disengage the clutch, so it grabbed a lot quicker and shifting was fun b/c it was quicker! however, when i give it WOT i mash the accelerator, and consquently i want to mash the clutch when shifting.
i got the normal feel back in about a week or so. it just takes the clutch a little time to get back to your normal driving habits. sorry i can't explain it better. i wish i could. but basically, what you described is normal when a new clutch is installed. but as you said, it has now gotten back to the way it used to be. so its all good.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
