| Off-Topic Talk about anything other than cars. |
I was wondering if you guys know what psi would you get out of a JoeP mbc when it is adjusted all the way to 0psi? because on mine the lowest it goes to is 16psi, is that normal? If so, how can i drop the psi a little like 12 or 13psi? Thanks for any help you guys can give me...
90 Eclipse Gs-T MODS so Far: ___________ Free mods upper front/rear strut bars Eibach sportlines springs Full 2.5" catback exhaust(custom) Buschur 2.5" Downpipe K&N filter small 16g Turbo Autometer boost gauge Apexi Turbo timer Greddy Type-S BOV |
Re: boost question again....
The lowest you can set will be what your wastegate actuator spring is. Your 16g's actuator is roughly 10-11 psi, so thats the lowest you can go.
I would remove the Joe P from the loop, running a straight line from the source you use right to the WG actuator nipple. If its 10-11 psi, its a problem with the MBC not going low enough. If its still 16 psi, you have boost creep, and will need to do some porting or other mods to reduce it.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Re: boost question again....
I was wondering, when you say remove it from the loop and straight line from the souce? i don't actually understand. Sorry...im still a newb.
Re: Re: Re: boost question again....
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Exactly. Remove variables so you can see what it really happening.
thanks guys...i tested it out today and the boost stayed at 10-11psi. So there is something wrong with my MBC...it is practically brand new, i don't know why there is something wrong with it...fu** What MBC would you guys suggest me getting that would be reliable and for a decent price? Thanks...
joeP should be good. try contacting them and see if you can get a free replacment. my guess is that you got a bad spring or something
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Yeah, if that was unscrewed all the way the spring is still too strong. I hear he's pretty good with customer service, I'd get in touch with him. I know Chad lost the internals to his (or maybe I did) and he sent them out for cheap money.
JoeP's have a tendencey to have a tight spring. Mine did, but I just took it apart and cut a TINY TINY bit off the top of the spring. Works perfect now
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
That will work
POSR style...
Thanks for the input fellas...i knew i wasn't trippin when my boost was too high, thanks!
