When I did my swap, I bought a brand new starter. Now it picks when it wants to start or not. Sometimes it cranks right up, other times, it just goes "click" Then if I push start it, after that it will start up fine the rest of the day.
Even today it did it at wal-mart, I let it roll back about 6 in then released the clutch, then tried to start it and it worked. Seems like the starter is sticking. Should I get a new starter or is there a relay or something that can be replaced? Thx |
Re: Starter problem
sounds like you have a bad spot in the starter motor windings. id replace the starter
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud. |
Re: Starter problem
There is a relay right above the hood release, but I doubt that's the problem.
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
Re: Starter problem
I should just get another starter then huh?
The only bad thing is I went to both of our local auto parts stores where I get my odds and ends, and they can't find anywhere on file where I bought a starter and I can't find my receipt!
you threw your old one out? Didnt you say in a post not too long ago, that if it isnt broken, then dont fix it? lol
ZC stuff http://dh-racing.com http://www.thezcr.com/html/zcbook.php http://dmoore.com/crx/zc.htm http://www.jgenginedynamics.com/HOME%20PAGE http://www.theoldone.com/
Re: Starter problem
i did an ls swap, starter didn't come with it.
Re: Starter problem
yeah, sounds like the starter is bad. Is it a brand new one? I doubt it's the relay because if that went bad then it wouldn't start with the starter at all
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles :: working on mechanical and cosmetic restoration ::
Re: Re: Starter problem
yea the starter was brand new when I put the ls in like a couple months ago, so I think the starter is fu<kin' up. |
Re: Starter problem
i hate when you feel more secure just becuase the part is new...(fucking alternators)
1988 CRX DX MODS: Garrett T28 turbo 450cc DSM injectors TurboEdit STD manifold W/adaptor plate dsm bov stealthemodeperformance.com oil line's Tsudo cat back basic hi flow cat front tower bar, rear tie bar short throw shifter and other small stuff |
Re: Starter problem
yeah, i have a feeling some of the "new" stuff is just "remanufactured" but they don't tell you
that or they make it wrong lol
Same problem
The car I currently have has the same problem, however my car has been through 3 or 4 starters. I was told its possibly a eventual defect with the ignition switch....
if it still looks new and has there name on it or there brand name or what ever then they SHOULD warranty it, u can tell if its new, old, barely used etc
1 year old will start to get surface rust on it usually, if not then buy a new one, take urs off, return it and say its the wrong one.... or it wasnt the problem, we get that all the time
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Re: Starter problem
if they wont return it all together, it will be cheaper for you to get it rebuilt, and its just about as good as a brand new one.
Saturn Stealership Technician #331 |
Re: Starter problem
Ok, well I replaced the starter (they exchanged it for me) and the mother fucker does the same thing.
So where should I start next? That relay, the big black box is what your talking about right? Then it might be my ignition!? Please help this is getting crazy, I can't hardly get around anymore. |
couple things to check would be:
-is the starter securely gounded?(try adding a ground, hard to explain why) -clutch safety switch working properly? -voltage drop to the starter -all connections good and no corrosion -ign switch your gonna have to track this one down, sounds like a tuffy but you can do it.
