Old 02-03-2005, 04:27 PM
BAKERBAKER BAKERBAKER is offline
No Vacuum 96 350 Just Checking
Having A Lot Of Problems With My Truck Still Put Fuel Pressure Test Today Turn Ignition 59 Lbs. Truck Running 53 Lbs. Pressure Regulator? I Checked For Vacuum I Have None Coming From Anywhere Through The Evap Area Plenty Through The Pcv Regulator Again ? I Just Think There Should Be Vacuum Couldnt Find Any Leeks Hooked Up Pump And The Gauge Works Sombody Help With That One.
Old 02-05-2005, 03:23 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: No Vacuum 96 350 Just Checking
Sounds like you've got a plugged port or two...or three. Pull the hoses off where the start, see if there's vacuum there. If there is, the plug is in the hoses. If not, use something like seafoam and see if that clears it out. I'd recomend putting it in the gas, oil, and intake.
Old 02-05-2005, 06:14 PM
Re: Re: No Vacuum 96 350 Just Checking
J-RI YOU BE THE MAN I WAS ALSO THE ONE WITH THE OIL IN THE INTAKE PROBLEM YOU REPLIED ON IM GOING TO THE BARN TO DOUBLE CHECK BUT I DIDNT FIND THE PORTHOLE TO THE EGR SIL. WHICH IS MOUNTED TO THE UPPER INTAKE BUT I BET IT IS THERE SOMEWHERE BURIED IN OIL. i JUST BOUGHT THE TRUCK CHEEP 96 K2500 EX CAB 4X4 FOR $ 2800 WELL I GUESS CHEAP IF I GET IT TO RUN BUT IT LOOKS GOOD SITTING IN THE BARN. THANKS AGAIN.
Old 02-05-2005, 06:15 PM
J-RI YOU BE THE MAN I WAS ALSO THE ONE WITH THE OIL IN THE INTAKE PROBLEM YOU REPLIED ON IM GOING TO THE BARN TO DOUBLE CHECK BUT I DIDNT FIND THE PORTHOLE TO THE EGR SIL. WHICH IS MOUNTED TO THE UPPER INTAKE BUT I BET IT IS THERE SOMEWHERE BURIED IN OIL. i JUST BOUGHT THE TRUCK CHEAP 96 K2500 EX CAB 4X4 FOR $ 2800 WELL I GUESS CHEAP IF I GET IT TO RUN BUT IT LOOKS GOOD SITTING IN THE BARN. THANKS AGAIN.
Old 02-05-2005, 07:13 PM
Re: Re: Re: No Vacuum 96 350 Just Checking
JUST WENT TO THE BARN AND GUESS WHAT THERE IS A PORTHOLE IN THERE WITH LOTS OF CRUD AND CRAP FILLED IN IT
Old 02-07-2005, 05:04 PM
Re: Re: Re: Re: No Vacuum 96 350 Just Checking
Originally Posted by bakerbaker
just Went To The Barn And Guess What There Is A Porthole In There With Lots Of Crud And Crap Filled In It
After Cleaning, Made No Diffrence But I Found Out That The Evep System Does No Have Vacuum In The Hoses Until The Engine Is Warm And It Is Ready To Accept The Fuel Vapors
