Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 02-03-2005, 03:34 PM
gbkwan gbkwan is offline
planning on buying a 01 frontier
Planning to buy a 01 Frontier with 60-80k miles. Anything in particular that i should look for in these cars? I'm looking at a 01 SE 5spd 2wd with 80k miles. I was trying to look for a 4x4 model, but none seem to be in my price range.
Any suggestions would be appreciated.
Thanks
Old 02-03-2005, 10:55 PM
radkonn radkonn is offline
Re: planning on buying a 01 frontier
I just bought a 2001 Frontier Crew Cab SE 5 speed. Overall, I feel like it is a good truck. I did take it in for a window regulator problem, but it was covered under a current recall. If you want to find out a lot of info on Frontiers check out this forum.
http://p085.ezboard.com/btunfs
Thanks
Old 03-28-2005, 02:28 PM
zeamays1 zeamays1 is offline
I wouldn't get an '01 Frontier. I have owned a CC 4x4 SE since new and am planning on trading it in. Too many defects, which seem to be common since I always find the solution on these boards.
1. Both windows started having trouble going up and down (25,000 miles) and would make horrible rattle when they were only half way down. I got it fixed under warranty, then it was recalled.
2. The Blower Motor Resistor went out around 50,000 miles. Very common problem.
3. Also around 50,000 Miles the ABS light came on, don't know what is wrong yet. Again this seems to be a common problem.
4. Around 60,000 Miles the knock sensor went bad. I don't know what it does but is is expensive and was somewhat difficult to repair.
5. Radio doesn't work on cold mornings. This one has only happened a few times, but under 10 degrees the radio just won't turn on??? No idea why.
