Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 02-03-2005, 01:38 PM
Guru_37's Avatar
Guru_37 Guru_37 is offline
Question Trac Off & Check Engine Light
After the check engine light came on and told us that we need new spark plugs, also evident from the mild shaking from the engine and misfiring. We replaced the spark plugs with new ones (Bosh Platinum +4).
From there, my dad was driving his 97 Toyota Avalon and the check engine light hasn't come off yet , but the car is running great now. As well, the car slipped a bit a stop sign when he pushed the throttle and the "Trac Off" came on, and it stayed on, even after we pressed the "Trac Off" button a couple of times.
What can we do to take off the "Trac Off" sign on the dashboard, also the "Check Engine Light."? - I know that the "Trac Off" means that the traction control is off.
Old 02-03-2005, 05:02 PM
pasco pasco is offline
you need to have the fault codes cleared. Once this is done, check engine and TRAC OFF light will go off. The button for TRAC will start working again.
Clearing codes can only be done using a scan tool. Go to Autozone or Murrays and they will do this free.
Old 02-03-2005, 07:01 PM
tfeld tfeld is offline
You can clear the ECU codes by just disconnecting the battery for 10 minutes too. But before you do so, if you have a radio with security code, be sure you know the security code, 'cause you'll have to reset it.
Old 02-17-2005, 12:41 AM
Joe W Joe W is offline
Re: Trac Off & Check Engine Light
On cars newer than 1996, the only way to clear the codes is with a scan tool. Also there have been reports of the +4spark plugs triggering codes.
