Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-03-2005, 12:44 PM
tipota tipota is offline
turboing a 92 240sx
is this engine at all setup for a turbo? i read in another thread that someone told another person to just get a turbo for their 240sx, and the link they gave led to just a turbo instead of a turbo kit.
now if you do need a turbo kit for the car, do you think it would be cheaper to buy the seperate parts rather than buying a whole kit?
Old 02-03-2005, 01:44 PM
drumpet15's Avatar
drumpet15 drumpet15 is offline
Re: turboing a 92 240sx
Yes, the KA24DE is definitely turbo-capable...do a search and you'll probably find a ton of old threads about this stuff. You will need the whole kit, though. You can't just pop the hood, toss in the turbo, and hope for the best. And I believe it would be cheaper to buy the seperate parts and put it together yourself. That way you can get exactly what you want too.
Old 02-03-2005, 07:43 PM
D-Bo's Avatar
D-Bo D-Bo is offline
check out www.boostdesigns.com they have kits ranging from something like 230whp to 500whp kits.. that'll give you an idea of what you'll need.. and yeah normally its cheaper to piece a kit together.. you can also pick and choose what you want and don't want, whereas in a kit, you get what you pay for. the stock internals will support up to about 260whp i think so unless you're serious about your power, you'll be fine.. just make sure you have good compression in each cylinder. thats very important when adding a forced induction system.. read up on how turbos work at www.howstuffworks.com i found that very simple to understand when i was first learning..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-04-2005, 08:35 AM
yea, ive read that before too and i do have a general idea on how turbos work. i have a question on piecing together a turbo. i know by looking at turbo kits what i should get, but fitting a turbo for a sepcific engine, are you really just making sure that it will fit? such as make sure the pieces you get are 35mm? and other than that you have to make sure they can withstand a certain pressure, and from there you just buy seperate pieces?
Old 02-04-2005, 12:14 PM
D-Bo's Avatar
well for the 240, there are a few turbos that are ka-sized-engine specific.. so no, you don't have to worry about that.. what you DO need to worry about is how much power you want going to the wheels.. the more power, the more money.. garett has always made good turbos that are very efficient and durable.. the t3/to4e is a huge turbo so it'll spool up at a higher rpm than say a t28.. so basically you look for either lots of top end power or a good amount of all-round power (by that i mean you'll get boost through a wider rpm range).. one is usually sacrificed for the other.. the turbo itself isn't the part you have to put together though.. you need to choose an exhaust manifold, downpipe and exhaust to start with.. there's a ton of other turbo threads with reccomendations for basic turbo setups.. check those out and you'll have a better idea
Old 02-04-2005, 11:20 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Answer the following:
1)How much power do you want?
2)What RPM do you want to make power
3)How much do you want to spend?
Good condition stock internals can hold 300-350whp daily driven with a good tune. I wouldn't try it without a JWT ECU for the timing control or some other form of timing control besides knocking back base timing. Stock internals don't give out from too much power until about 400whp.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 02-05-2005, 05:13 PM
240droptop 240droptop is offline
Send a message via MSN to 240droptop
my budy turboing his Ka he just bought a 300zx turbo
The only way to Drift is with the top down and your own rubber spray hitting you in the face
Old 02-05-2005, 05:45 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Ok...I didn't ge that...
Old 02-05-2005, 08:40 PM
id just like to take off faster at lower rpm's. i drive mostly in the city, so if i can boost around 3000-3500 thatd be great.
Old 02-05-2005, 11:40 PM
240SX Guy
www.boostdesigns.com has a great kit for you. It will give you the quick spool you want with peace of mind of a 1 year warranty.
Turbos are not car specific, but more engine specific. They are desinged to put out a set amount of air with a set amount of propulsion. Some range very broad, some very narrow. I believe the turbo you are looking for is a T3/T04E with a 50trim wheel. Nice broad range, quick spool, and pretty capable.
EDIT: Thanks Hit N Run
-Cory
12.6@122mph
Old 02-05-2005, 11:44 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
nissan made a typo, its all good
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 02-06-2005, 12:09 AM
Tims_240's Avatar
Tims_240 Tims_240 is offline
u sure about that? his link worked fine for me, unless he went back and changed it real fast, sneaky basterd.
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 02-06-2005, 12:13 AM
lol, yeah he did. He is a very sneaky one....i got my good eye on you!
1988 conquest TSI
Torque wins races!
Old 02-06-2005, 12:27 AM
i just have a quick question. i know if you turbo some cars, you will need to change the transmission to handle that extra power. is that true of the 240sx also?
Old 02-06-2005, 12:28 AM
no, you might want to get a stronger clutch to handle more power. But i dont see why you would want to buy a new tranny, what brand makes aftermarket trannys for the KA?
1988 conquest TSI
Torque wins races!
