Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-03-2005, 12:15 PM
DAGAME DAGAME is offline
98 ex still having idle problems
1 month ago my car sometimes would idle at 1500 rpms and the cel went on and when my car would do this it would jerk back hard when i pressed or let go of the gas. So i replaced the air idle control valve and the cel went off and drove fine for a week, then it did it again and gave me the same code off the cel, what could be my problem?
Old 02-03-2005, 03:57 PM
lorunner lorunner is offline
Re: 98 ex still having idle problems
What was the exact code number? P???
Stop asking me about radio codes I cant get them anymore!!!
Old 02-04-2005, 11:02 PM
dont remember the code number, but it was idle control system malfunction.
Old 02-06-2005, 05:37 PM
code is P0505, had 7 possibilities of what the problem could be, my mechanic at work checked all of them and everything is working fine, what could the problem be? Should i start saving for a b18?
Old 02-06-2005, 07:51 PM
Hmm did you check for any vaccum leaks? Intake gasket, Throttle body gasket, etc.
Old 02-06-2005, 10:15 PM
checked, throttle body clogged/in proper adjustment, vaccum leaks, throttle body position sensor, IAC Manfunction, ect.
Old 02-07-2005, 10:47 AM
alright here is exact list of what my mechanic checked and everything is working perfectly, but yet the idle is fucked up, IAC valve mechanical malfunction,throttle body clogged port/improper adjustment, intake manifold gasket leak, intake air hose loose leakage, vacuum leak, ECT sensor incorrect output, throttle position sensor incorrect output.
