Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-03-2005, 10:13 AM
98AUR0RA 98AUR0RA is offline
Send a message via AIM to 98AUR0RA
Voltage
THe voltage on mt DIC reads as high as 15.7. The norm is 15.4. Is this normal for auroras? Do I have anyhing to worry about?
Old 02-03-2005, 11:40 AM
OldsAuroraMan1 OldsAuroraMan1 is offline
Re: Voltage
My 1998 Aurora reads the same. From all I have read, this is the norm for the Aurora. It's a "High Energy Car!"
Old 02-03-2005, 03:38 PM
newscarver newscarver is offline
mine also reads in the 15 range in the winter when the heater fan, seat heaters,rear window defroster,wipers and headlites seem to be on more often.
Old 02-03-2005, 08:02 PM
Isnibs's Avatar
Isnibs Isnibs is offline
From what I have been led to understand the voltage you read at the DIC is the volts being accepted by the battery.
The battery has a thermistor (temp sensor) and will allow more volts input when it is cold, regardless of what accessories are running.
In temps of around 0 DegF and lower, a voltage of 15.7 is acceptable but as the battery warms up the input drops.
In summer 15.4 volts seems the norm.
isnibs
1996 Aurora Black / grey
Old 02-04-2005, 11:52 AM
kayaman420 kayaman420 is offline
Re: Voltage
isnibs
yeah when it gets to zero degrees or below my voltage can get to 15.5 sometimes. Then in warm weather it usually hovers more closer to 15.
Thought I had some kind of regulator problem. Im glad i read this post.
Aurora 4.0---Anything less would be uncivilized!
http://members.cardomain.com/kayaman420
