Old 02-02-2005, 11:46 PM
G35turbo G35turbo is offline
Exclamation I found this on 3si.org!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hey
as most of u guys now its really hard to sign up on 3si and it wont let me sign up. Anyways i found this on 3si.org (http://www.3si.org/forum/showthread.php?t=254540)
Right after I picked up my TT I decided to replace all the fluids in the car. The first two weeks of owning the car, the shifting was rough. It was difficult to get into 1st, 2nd and 3rd gear. Reverse was also sometimes difficult. Double shifting seemed almost hopeless and I started calling shops to see how much it would be to replace synchros.
I held back from buying the BG Synchroshift, figuring that I had to replace the synchros anyway. Until one day the gears grinded so badly that I dropped it off that day.
First Impressions:
I'm not really sure it made a difference. Shifting was a little smoother, but I wasn't sure if it was the warmer weather or the BG Synchroshift. It was still difficult to get into some gears and reverse was still a pain.
After a couple miles:
I can't believe this stuff actually works! The shifting is effortless and every gear is easy to get into. Even reverse is no longer a problem. A couple of days ago it was -3 degrees outside and there was absolutely no problems with the shifting.
I highly recommend this. Even if you think your synchros are completely gone, try this first. It might end up saving you from having to spend a couple hundred dollars now.
My question what exactly is BG Synchroshift??? Is it fluid, where can i get it???
Hope fully this can fix all the problems other people have like me with there gears.
If u guys dont now where to get it and dont now anything about it, if you have account with 3si.org please post a reply and ask him. I cant do it because it wont let me have a account with 3si.org
THANKSs
Old 02-03-2005, 01:03 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: I found this on 3si.org!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Its MTX oil. You can pick it up at almost every car parts store.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-03-2005, 01:18 AM
sLADe781 sLADe781 is offline
Anyone here ever used it before? Or heard anything about it? 'Cause I'm gonna need to replace my synchros probably but would prefer a "cheaper" solution (if there is one).
Old 02-03-2005, 02:29 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
haven't used it, but its probably a good buy. i put Pennzoil Synchromesh MTX fluid in mine. it was much cheaper than BG ($7/qt compared to $15/qt) and i felt great difference in improved feel and smoother shifts. GM Synchromesh and Pennzoil Synchromesh are the same product of tranny fluid. But for some reason, the Pennzoil is cheaper and easier to find. check out www.midwayautosupply.com if you can't find it at a local auto store.
if you want BG, then i think 3sxperformance.com sells it. pricey tho, @ about 15/qt.
Oh, and G35Turbo, the reason why 3si.org most likely "won't let you sign up" is that you have a free e-mail account, like yahoo or hotmail or something. You sorta need an e-mail with an ISP like swbell.net or earthlink.net.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-03-2005, 07:51 AM
Linebckr49, thx. I will try with dose emails.
Old 02-03-2005, 12:22 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: I found this on 3si.org!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Same for me, $7 a quart at Autozone. Same results.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-03-2005, 04:20 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Is it easy to change ones tranny fluid? How many quarts are needed?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-03-2005, 05:52 PM
2.something, so buy 3 and an oil pump. And this is only for MTX transmisions. There is a drain ahd a fill plug on your trans. Lift the car but make sure its level. Take out the drain plug and let everything drain out. Put the drain plug back in and remove the fill plug. Pump the oil into the transmision until it comes out the fill hole. When it starts to come out is when its full. Put the fill plug back in.
Old 02-03-2005, 07:06 PM
StealthModifier StealthModifier is offline
how is it hard to sign up on 3si?
Old 02-03-2005, 07:55 PM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
as hard as it is to sign up on AF
Thourun's Avatar
It took me months since I forgot my earthlink password.
1995 3000GT VR-4
Old 02-03-2005, 08:09 PM
I dont use earthlink. Is there anythoer website that i can use to sign up with 3si.org, I tired both earthlink.com and swbell.net but both you have to use there internet to get a free email. If i am wrong tell me were to look for the free email on this 2 websites.
Old 02-03-2005, 08:32 PM
Thourun's Avatar
Yea thats the thing, they don't want you using a free email. You could try to find an obscure providor of free email that might not be banned, can't sugest one though.
1995 3000GT VR-4
Old 02-03-2005, 09:45 PM
i finally joined 3si on the 23rd. same name as what i have now i know u cant just sign up by going to join now. i went to it by another way
Old 02-03-2005, 10:40 PM
what way is that????
