Old 02-02-2005, 10:49 PM
Xrrider280's Avatar
Xrrider280 Xrrider280 is offline
Send a message via AIM to Xrrider280
What is a knock sensor
I'm told when swapping a 305 to 350 i need to change the knock sensor. Does this mean put the 305 knock sensor on the 350? Also where is the knock sensor.
Old 02-03-2005, 09:45 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
I would not have thought you would have to change it but, oh well. It sounds like you need a knock sensor from a 350 because the one from the 305 won't work. They bolt into the side of the block towards to front. Mine is in the block by the starter. You will see a wire that plugs into a round thing that is threaded into the block. What these do is they detect noise, so if the timing is off or you have any fuel issues or anything that wouls cause your engine to spark knock, they tell the computer to retard the timing until the spark knock goes away.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 02-03-2005, 12:09 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: What is a knock sensor
~bingo~
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
