Old 02-02-2005, 09:32 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
o2 sensor location
cant find it online anywhere, wheres the location of the o2 sensor on a 95 eclipse gst, its not on vfaq.com so dont direct me there lol
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-02-2005, 09:38 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: o2 sensor location
On the o2 housing and right after the cat.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
there are 2 o2 sensors. on before the cat (or lack of in your case ) the second is after the cat. im not sure exactly where on a 2g but if you want to get rid of the cat code you have, then this is the o2 sensor you need to "fix"
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-02-2005, 09:49 PM
well i need to install my af gauge and there should be a relay on my ecu, just need to kno where to do it and maybe find a step by step
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 09:52 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
If I get around to it this weekend I can tell ya the wires you need to splice off of from the wire harness/ecu
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 02-02-2005, 09:53 PM
k cool thanks
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 09:55 PM
Are you sure you want it? It really has NO use.... just has led's that bounce back n forth... I plan on swapping it out with something usefull like coolant temp or fuel pressure or whatever...
Old 02-02-2005, 10:31 PM
yea, at the moment i dont have anyother gauges
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 10:38 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Who cares if you have any other gauges? They are 100% useless, don't use it. What was said above is correct... tap the ECU signal, not a wire that's 6,000 degrees, you probably don't have the right non-melting wire/sleeve like the stock o2 sensor uses. The front (gauge) o2 sensor is in the o2 housing (imagine that) right between the turbo and the downpipe. The second one is for emissions and is near the cat, and very easy to find.
Old 02-03-2005, 06:06 AM
actually its incorrect because both those links are for a 1g, i have a 2g.
second i do have the heat sleeve, its sitting in the box
i kno to connect it to my ecu and thats what im trying to do if i can find the right person to tell me where it is, thankyou
95 Eclipse GS-T
Currently:
Soon lol
Old 02-03-2005, 05:09 PM
kjewer1 kjewer1 is offline
AF - Advisor
Both www.vfaq.com and www.roadraceengineering.com should have instructions for this. If nothing else, the vfaq has an ECU pinout, use the wire for the front o2 signal. Take the ground from the ECU's sensor ground, or there will be a voltage offset making the guage less acurate. Now, the info you get from the sensor is not very useful, so gauge accuracy isnt a big deal anyway.
And just for the record, the guages are very accurate at displaying voltage for the most part, its the narrowband sensor that is useless.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-03-2005, 05:35 PM
Isn't our O2 sensor a wide band? and the guage a narrow band? That's what i've heard and explaines why it just bounces ALL around......
Old 02-03-2005, 05:40 PM
AF - Advisor
Nope. Stock sensors are both 0-1 volt. Thats why many poeple just use a voltmeter to read it, and even the ECU does the same, and you always hear about the 1 volt limit. Common WOT ranges are in the .90s.
A wideband sensor like I use on the 2g is 0-5 volts. Much higher resolution, and its also meant for full range measurement, not for simply siwtching between too rich and too lean (hence the reason the O2 trace "cycles").
Kevin Jewer
Old 02-03-2005, 07:30 PM
where can you buy a wideband and what do you need to do to the ecu for it to be able to read it right? im guessing that since it goes from 0-5 instead of 0-1 that the ECU wont like it.
-1stGenRocks-
Old 02-03-2005, 09:34 PM
SLoe's Avatar
SLoe SLoe is offline
Do a yahoo search, there are a ton of kits. AEM, Alamo motorsports, there is even a DIY wideband kit.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
