Old 02-02-2005, 08:57 PM
Leesmack Leesmack is offline
how to tell if fuel pump is messed up??
title says it all!!
Midwest Meet in Saint Louis this Spring 2005!!!!
1st Midwest Meet
90 honda civic hb 4 spd manual
short throw shifter
ngk platnium plugs and wires
castro synthetic oil
Old 02-02-2005, 09:07 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: how to tell if fuel pump is messed up??
if your car doesn't turn on lol
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-02-2005, 09:33 PM
midrange midrange is offline
Send a message via MSN to midrange
lol.. your car won't start.. or while running.. it will stall.. thats about the only way to put it i think.. I mean, you can't really tell if its starting to die.. your engine gets the fuel or it doesn't..
Old 02-02-2005, 09:44 PM
icE_x's Avatar
yucky...anyone know how long the stock fuel pump usually lasts till it needs replacement? I guess it varies with each car, but there might be a round figure? This way i can go ahead and replace it around xxx,xxx amount of miles so i won't be stuck in the road somewhere with a dead fuel pump.
Old 02-02-2005, 11:25 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
On cars as old as ours just wait till you start to have problems with it till you replace it. Chances are, it will last you till you dont own the car anymore.
......Hope i didnt jinks you
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-03-2005, 12:47 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
a problem that i had with my fuel pump was the ground, the ground got corroded so i pulled the pump thinking it was the pump but when i hooked it up to a battery, it worked but i installed a new pump anyways
Team Lonely Drivers
Old 02-03-2005, 06:43 AM
my 88, i am pretty sure is still stock.. so far it still seems fine.. so 17 years so far.. no bad... and civickiller had the same problem as me last summer.. my fuel pump stopped working. so i dropped the tank and before we went crazy pulling it out, i said to my dad, i'll turn the key and see if you can hear anything. and sure enough, just dropping the tank moved the wires around and it fired right up... never had a problem since..
Old 02-03-2005, 11:04 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
my buddy just replaced his in his 88 firebird. it finally crapped out on him the other night, his car was a bitch to do tho, 6 hour job, had to drop the exhaust and some supports in the rear
Old 02-03-2005, 12:05 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
whyd you drop the tank? You couldve gotten to it from underneath the back seat. There are little trap doors on almost all hondas that lead to the fuel pump and the fuel sending sensor or what ever its called.
1991 Honda Civic DX Sedan
Old 02-03-2005, 01:09 PM
1PhatCX's Avatar
you have to drop the tank to do fuel pumps in our cars. that "trap door" is for the sending unit only
Old 02-03-2005, 01:46 PM
Re: Re: how to tell if fuel pump is messed up??
dude we already told you, that you were wrong in the other post. what still dont believe the guy that has actually changed his fuel pump before ?
Team Lonely Drivers
Old 02-03-2005, 02:27 PM
CBURKE's Avatar
CBURKE CBURKE is offline
When a pump goes bad you can sometimes here is knocking. There is a little piston inside and when the pump starts to give out it knocks, kinda like the bottom end of a car when you spin a bearing. It will also stall after it warms up. You would have to keep you foot on the gas so it will not stall.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 02-03-2005, 07:42 PM
thats true, if its a mechanical fuel pump that is attached to the block and mechanically powered by the crankshaft. I never heard of that problem on an electric fuel pump inside the gas tank.
Old 02-04-2005, 09:10 AM
CBURKE's Avatar
look ass, i said sometimes, and my bad i was thinking mechanical fuel pump. (dick)
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 02-04-2005, 11:30 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
it does become noisier when its going out, so you were somewhat right. when they start to go bad, the slight hum you normally hear when you turn the key to the "on" position changes into a loud buzzing sound.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
