Old 02-02-2005, 08:02 PM
brots06 brots06 is offline
Send a message via AIM to brots06
Question cigarette lighter doenst work??
One day my cigarette lighter on my '99 grand am stopped working, i was using it for a radar detector and thats it, i double checked it with a cell phone charger and that wouldnt work either. I pulled out every single fuse and none of then were burned out, i took apart the dash and the wires behind the cigarette lighter are connected and look fine, any ideas??
Old 02-03-2005, 09:43 AM
bump
Old 02-03-2005, 12:19 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
Re: cigarette lighter doenst work??
I would check your fuses again, make sure its the right amp for the cigarette lighter(look in the manual) or it could be a bad wire or short.
Old 02-04-2005, 06:05 PM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
sometimes the fuses will burn out but you will not be able to tell just by looking at it. Get a multimeter and check them for continuity.
Old 02-18-2005, 01:31 PM
russellhurley russellhurley is offline
You may have a bad cigarette lighter itself. Take the dash apart again, remove the lighter and replace with a new one (approx. $5.99)
Old 02-20-2005, 01:22 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
This is common when using lighter accessories. What happens is a tab bends and makes a short inside the lighter housing. This is most likely if your popping fuses. Lay off the accessories on that lighter mount , put in a multi point lighter accessory to use your radar detector. I found that when you put in a radar detector and it works without popping a fuse then leave the power connector connected or else theres gonna be repete reprocussions. "More popped fuses and rebending tabs"
IMO from personall expirience with the same car.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
