Old 02-02-2005, 07:08 PM
Powerefx Powerefx is offline
Re Audio Components
Are the RE Audio Re components any good? How much are they origninally now that they are on sale for 130?
Old 02-02-2005, 08:25 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Re Audio Components
Yes they're very good for the money......they're not tthe greatest things in the world though..... They're pretty bright and a little harsh, but not anything horrible.... for the money that and the CDT Ef-61 set are great.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-02-2005, 09:29 PM
havent really worke with compnents yet, was wondering if i can take two 4ohm speakers(components) and apply the to a singe channel, instead of one speaker to left and one to right chanel, on a two channel amp?
Old 02-02-2005, 09:33 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
do you mean the mid and tweet on 1 channel?
or do you mean both mids and both tweets on 1 channel?
if it's the former, yes, that's what the crossover is for, it splits the frequency so the lows go to the mid and the highs go to the tweet, and the amp still sees a 4ohm load on that channel
if it's the latter then yes, but then you'll be sending the same signal to both your R and L speakers (or R front and R back, depending on which pair you're wiring to the single channel). Your amp will also be running at 2ohm on that channel, which should be fine for just about every 2ch amp out there.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-02-2005, 09:38 PM
So basically i can run four speakers on a 2 channel amp right?
Old 02-02-2005, 09:41 PM
sr20de4evr's Avatar
you could run 25 speakers on a 2ch amp if you wanted to, as long as you watch the impedance
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2005, 09:44 PM
Lol thnx, so juss wondering, how would u set up the wiring would it be the wiring from the crossover you would need to adjust, or like u connect both negatrive of the speakers, and bothe postivies and the put it on the crossover?
Old 02-02-2005, 09:50 PM
sr20de4evr's Avatar
for a single set of components on a 2ch amp, you would run wire from the +/- on one channel to the +/- on the input of the crossover, then from the +/- woofer output to the woofer, and the +/- tweeter output to the tweeter. Then the same goes for the other channel.
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2005, 09:56 PM
Srry dont really get that, you just used on woofer and tweeter what about the other, were u connect that?
Old 02-02-2005, 10:09 PM
sr20de4evr's Avatar
eh?
a common crossover will look like this:
there's a + and - input that comes from the amp, a + and - output that goes to the woofer, and a + and - output that goes to the tweeter
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2005, 10:20 PM
what im trying to say is that will their be a wire connecting the twoo woofers together and the twoo tweeters together, or will two wires go from each, on to on woofer and the next to the other woofer
Old 02-02-2005, 10:30 PM
sr20de4evr's Avatar
well if you're putting a single set of speakers (2 mids, 2 tweets, 2 xovers) on a 2ch amp then each side (each xover/mid/tweet set) will have its own individual channel of the amp, you won't wire them to each other at all. If you're putting 2 sets of speakers (4 mids, 4 tweets, 4 xovers) on a 2ch amp then you would connect each channel on the amp to the inputs on 2 xovers, and each xover will have its own mid and tweet.
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2005, 10:40 PM
so that would be connecting the positive of one crossover input to the positive of the other input, and then connecting one of the postives to the postive input for the amp. and the same with the negatives
Old 02-02-2005, 10:52 PM
sr20de4evr's Avatar
yeah, if you wanted to put 1 set of speakers (2 mids, 2 tweets, 2 xovers) on 1 amp channel. I'm guessing you want to do this so you can have the front and rear speakers all running on a 2ch amp? If so that will work, just keep in mind that you'll lose the ability to fade.
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-02-2005, 10:59 PM
SKyleS's Avatar
SKyleS SKyleS is offline
Where the hell can I buy these? I hear so much about them and I have found nobody that sells them.. (Don;t give me a link to thier site, I know it and couldn;t find where to buy.)
