Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-02-2005, 04:30 PM
2of9 2of9 is offline
Engine Potential?
Yes, I know the 4G63-T engines have ALOT of potential, but one of my Toyota buddies told, just now, that the 3S-GTE engine from a...90-94? MR2 Turbo or a Celica All-Trac???(dunno, but should be close) has just the same amount of "potential" a 4g63 engine has. Almost any turbo car, i know you can have potential just by BC, air filter, pipings and FMIC, but is it tru that the 3SGTE or the 3S-GE motor (stock vs stock) has the same potential as a 4g63T motor? well, if you guys dont really understand, ill write again...THANKS!
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 02-02-2005, 06:05 PM
Raz_Kaz Raz_Kaz is offline
Re: Engine Potential?
4g63 engines have claimed to push 400 horses with stock internals.
Not too familiar with the toyota engines though
Old 02-02-2005, 06:13 PM
joemathews's Avatar
joemathews joemathews is offline
I don't believe MR2 or Celica all-trac motors can claim 500 hp stock block and internals performance like the 4g63 can. However, putting 300 hp out in a car that only weighs 2600 lbs. makes its potential grow fast
1996 Eagle Talon
Old 02-03-2005, 05:51 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Stock 3SGTE's in the MR2 have gone over 500 rwhp.
I'm currently at 200,222 miles on my original, unopened 3SGTE (documented). I put down 351 rwhp and I have done: over 120 passes on the drag strip, 20+ dyno pulls, 3 SCCA Solo 1 hill climb races, 5+ SCCA Autocrosses and lots of abusive street driving.
I'm currently racing at 24.5 psi of boost. 100% original engine
... I should be at 425~450 rwhp by Spring.
You need to lose a bunch of weight to get the MR2 to 2600 lbs though. They are 2800-3050lbs from the factory depending on options.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 02-03-2005, 12:09 PM
joemathews's Avatar
Re: Re: Engine Potential?
Great info! That shocked me...I didn't realize they were that heavy, or could put out that much power on a stock motor.
1996 Eagle Talon
Old 02-03-2005, 03:41 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Actually I know a guy that did a 524whp run on a dyno here in MN and I was there to witness it. Also there was quite a few post about a guy that did 556whp. Its all on how you treat and tune your motor. That will determine how much power you make from it.
NOTE: Those numbers were on a 7 bolt block~
Old 02-03-2005, 05:50 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
How would eclipse people know about MR2 capabilities? The record I've heard is ~550whp on a stock 7 bolt 1g block. This is the one that was a few months ago on the DSMlink forums. Did you mean a built motor? shep should be well over 800whp now, and who knows how much rau and buschur have... 1200 flywheel? bench dyno at the least. Why all these theoretical questions?
Old 02-04-2005, 09:17 PM
EclipseRST's Avatar
Banned
I dont know if you were talking to me but the one I saw that made 524whp was a 96 GSX and had the stock motor in it with cams and the apropreate bolt-ons necessary to make that power. Nice ass car!
Old 02-05-2005, 02:01 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
That was on a stock 7 bolt block?? Just imagine what the 6 bolt can do then. Sure people say it can handle 400hp, but that is a little more than that!!!
"You can have everything in life you want if you will just help enough other people get what they want."
