Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-02-2005, 04:01 PM
ejazz ejazz is offline
Oversize tires
I am thinking of putting 285/75/16's on my '98 1500 4x4. It now has the 265/75/16's. Has anyone done this and did it have any negative effects on the shift points, overdrive, or anything else. I know it will affect the speedometer. Some of my buddies made the change on there Chevy's with bad results.
Thanks
Old 02-02-2005, 07:57 PM
440Duster 440Duster is offline
Re: Oversize tires
I don't know if this will help or not but i have a ramcharger with 33 by 12.50's on it and the shift points and overdrive work just fine. and if i'm not mistaken but a 285 tire is around 10 inches wide and about 27 inches tall but i'm no expert but it dousn't seem like it should have a problem at all. unfortunately that is all the advice i can give you but i hope you have good luck with it.
Old 02-03-2005, 09:13 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Oversize tires
I have 265/75R16 on my truck now, and have also been thinking of changing to 285/75/R16 as well.
I went here http://www.dakota-truck.net/TIRECALC/tirecalc.html
and put in the tire sizes, and it says that the 265/75r16 is roughly 32"x10.43"x16 , and the 285/75r16 is roughly 33"x11.22"x16. these are just rough demensions, as actuail size will varry by manufacturer.
also, with the larger 285's, the spedo will read low by about 3.6%
sense the 285's are only about 1" taller, it shouldn't effect the shift points, but if it dose, if you have a programmer, or take it to the dealership, the computer can be adjusted for the new tire size, wich would correct any effects on the shift points.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 02-03-2005, 11:29 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Oversize tires
Also check out:
http://www.1010tires.com/TireSizeCalculator.asp
for more tire size calculations.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-04-2005, 11:03 PM
HemiGottaLuvIt HemiGottaLuvIt is offline
Send a message via MSN to HemiGottaLuvIt Send a message via Yahoo to HemiGottaLuvIt
Re: Oversize tires
I'm running 285/70r16's on my 98. The tire calculators are great and give you good ballparks to play with. Like scoutinkeith says reality isn't always getting the memo about what the calculator says. My tires actual height 30 1/2".
I've noticed to issue with shift points as this tire isn't too much larger than stock.
Consider paying more attention to your steering clearance. The larger meats may rub when you make turns lock-to-lock.
