Old 02-02-2005, 02:54 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Boost and AF Gauge question
Ok, for the boost gauge, where would i connect the orange wire(12v lighting? Second, can I find a detailed installation of installing a AF Gauge, unless someone wants to post it here...95 Eclispse GST is what i have. The AF gauge has the red, black and gray wire and im not sure what goes where the gray wire goes. Im assuming the black and red correspond with the boost gauge ones. Thanks guys
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-02-2005, 03:31 PM
Re: Boost and AF Gauge question
now that im thinking about it, would both 12v wires connect to the same place?? or am i wrong, if so where else besides the cig lighter would work?
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 03:37 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Anywhere with 12v power will work. A spare fuse slot, the cig lighter, the battery itself technically would work. That said, don't do it to the battery. On your AF gauge, you are going to have power, ground, and signal. It's an ECU wire that you tap, but since A/F gauges are useless and a waste of money, I don't know offhand what wire it is.
If you want to dim the gauges with your instrument cluster, you can use the dimmer switch so I've heard.
Old 02-02-2005, 04:11 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
vfaq.com has a detailed install for the A/F guage and what wires to tap into.... but otherwise it isn't really worth it...I know from experience.......
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 02-02-2005, 08:21 PM
Ok, looked on vfaq, thats for the 1gs, anyone know where i would put the sensor for the AF Gauge on a 2g?
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 08:37 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
look harder.
http://vfaq.com/mods/gaugelit.html
http://vfaq.com/mods/wayback/BradBau...l/find-o2.html
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-02-2005, 09:09 PM
yea i looked at those and i have a 95 gst, its not the same, thats why i asked
95 Eclipse GS-T
Currently:
Soon lol
Old 02-02-2005, 09:37 PM
I have the same sh!t as you... it will work...
if you look close enough your nose will touch the screen.
all you have to do is find the right pin number on the harness to jump off of for power and signal wire.
Old 02-02-2005, 09:44 PM
Wait... I just looked and the original page that I used isn't there anymore... I had it in an email but it is gone...damn
Old 02-02-2005, 09:47 PM
Im only worried about the o2 sensor, i can do power and ground myself because im putting a switch and led to it, i think i might have found something tho...when you installed it did it involve taking off the drivers side access console to the ecu?
95 Eclipse GS-T
Currently:
Soon lol
Old 02-03-2005, 05:11 PM
kjewer1 kjewer1 is offline
AF - Advisor
Yes, thats where the ECU is, so thats where the wire is. This isnt rocket science poeple. There is also a ECU pinout posted on vfaq.com that will tell you what wire on what connector is the signal line for the front O2 sensor. Use the ECUs sensor ground, see the other thread I just replid to for the reason.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-03-2005, 05:21 PM
AF - Advisor
Let me do it for you.
http://www.vfaq.com/mods/ecu-harness-2G.html
Pin 76 for 2G turbo is what you want.
It doesnt really show where the ground wire is, so lets think about this. The AFC has an oddball grounding setup, lets check the instructions there.
Ah yes,
http://www.ecanfix.com/~aclifford/tr...perafc/afc.jpg
and
http://www.prostreetonline.com/pso/p...p?articleid=25
Another alternative is given here:
http://www.vfaq.com/mods/wayback/afcinstall.html
Kevin Jewer
Old 02-03-2005, 05:32 PM
"NICE" lol
