Old 02-02-2005, 02:26 PM
mayo_1981's Avatar
mayo_1981 mayo_1981 is offline
Send a message via Yahoo to mayo_1981
S2000 with SAS body kit and Mugen hood paint questions
If I spray Tamiya pearl white by itself with a few coats, should the white pearl come out good? Or should I spray a gloss white under the pearl? Suggestions, comments anyone. I didnt' see this in the FAQ.
Also, can enamels and acrilycs be mixed if you add one when another is dry?
Coming Soon!!!
Tamiya Honda S2000 w/SAS body kit, hood, and rear wing
Tamiya F50
And Much More!!!
Old 02-02-2005, 03:11 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Paint a base coat of white first, otherwise whatever is under the pearl white will show through. - Mark
Old 02-02-2005, 03:13 PM
mayo_1981's Avatar
The only gloss white that I have right now is Model Master enamel will that have a bad reaction to Tamiya pearl white?
Coming Soon!!!
Tamiya F50
And Much More!!!
Old 02-02-2005, 03:17 PM
blubaja's Avatar
blubaja blubaja is offline
Re: S2000 with SAS body kit and Mugen hood paint questions
Hey,
I would wait untill you get a tamiya white. But, you should paint white 1st. Tamiya pearl is very translucent.
Frank X.
Vric's Avatar
Vric Vric is offline
if you use White Primer, it will be ok, else you will need a White base. Also, a clear coat is recomanded.
Yes, it will wrinkle. You can use Tamiya white Primer as a base coat too. Just make sure it is uniform before you start shooting the pearl. - Mark
Old 02-02-2005, 03:23 PM
ZoomZoomMX-5's Avatar
Agreed...I just painted a pearl white model using Tamiya white primer as a base coat and Tamiya pearl white over it. Even Tamiya pearl clear should be clearcoated...though it doesn't have much pearl to it whatsoever...I resorted to using some of my old LMG pearl powders to punch up the pearl effect.
I wish Tamiya white primer covered better...it was yellow plastic and it wasn't covering well at all, I resorted to spraying Tamiya gray primer over it and then shooting the white primer.
My Fotki Album
Old 02-02-2005, 03:41 PM
mayo_1981's Avatar
Thanks for the help. If I hand paint the gloss white, then sand, then spray pearl white will it turn out okay? I wont be able to get a gloss white spray for a while. I do have an enamel gloss white spray by Model Master, can I use that?
Coming Soon!!!
Tamiya F50
And Much More!!!
Old 02-02-2005, 03:44 PM
Don't use enamel under the Tamiya Pearl White Lacquer.
Brush strokes will show through too.
I'd wait until I could do it right.
Seems there's never enough time to do it right the first time, but there's always enough time to do it over again... - Mark
Old 02-02-2005, 03:46 PM
Applying Tamiya spray over Testors/Model Master spray is risky...others say it will wrinkle the paint underneath. I tried it once on a test body, and no problem at all...fresh Tamiya clear over freshly applied Testors/Model Master. But that may have been a fluke. Tamiya sprays are pretty mild lacquers. You might try the combination on a test body to see if it will work, and then be very careful to apply the Tamiya pearl white in light coats.
Don't hand paint a model....you will not be happy with the results! You spend too much time w/the body and the resin mods to then do a paint job worthy of an 8 year old. '
You're better off waiting until you have the right paint before making too many potential mistakes.
My Fotki Album
Old 02-02-2005, 03:52 PM
mayo_1981's Avatar
AHHH!!!!!! Its taken me close to 8 months to finish this! Now that I'm so close, I have to wait. Oh the sadness.
Thanks everyone!!!
Coming Soon!!!
Tamiya F50
And Much More!!!
Old 02-02-2005, 03:54 PM
All the more reason to wait and do it right. Trust me, the time spent waiting may seem long now, but will seem like nothing when it comes out good in the end. - Mark
