just used lucas oil product fuel treatment
I have used the oil before and was pleased today while browsing at parts store I seen the fuel treatment on sale so I picked up a bottle (one bottle treats 25 gals so I used about half) Dont know how but the motor seems quieter then before use only reason I noticed was I didnt have any complaint before hand. I was just kinda like wow its quieter.
One claim made with the fuel treatment is it acts as an UPPER CYLINDER LUBRICANT Lucas Fuel Treatment cleans and lubricates valves, pumps, carburetors, injectors and compression rings. I'd recommend it. has anyone else used it? lucas oil site "Lucas Fuel Treatment is for gasoline, LPG and diesel fuel. It contains no alcohol, solvents, kerosene, diesel fuel or anything else that would be useless or harmful to engines. Low sulphur diesel fuel and reformulated gasolines have had the polymers removed from them, not because the polymers were harmful but because they were attached to the aromatics (fumes) in the fuels. In their zest to rid our air of gasoline and diesel fumes, our government has stripped our fuel of its main lubricants and, in the process, a great deal of its power. Lucas Fuel Treatment replaces those polymers with a concentrate that makes the fuel slicker and more powerful than it was originally. In fact, the user usually picks up more than enough fuel mileage to pay for the fuel treatment itself. Lucas Fuel Treatment lubricates rings and cylinder walls for longer life. It causes more combustion for more power and higher fuel mileage with FEWER EMISSIONS. Lucas Fuel Treatment cleans and lubricates valves, pumps, carburetors, injectors and compression rings. It is an absolute must for rotary pumps! It extends the life of catalytic converters and raises the octane to eliminate spark knocks. Lucas Fuel Treatment safely replaces the need for lead in older engines. Lucas Fuel Treatment is an excellent diesel tune up! Before going to the shop with an engine that is smoking or low on power, we suggest that you try adding about a half gallon of our treatment to each 100 gallons of fuel. This is often all it needs!"
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks |
Re: just used lucas oil product fuel treatment
I have been using Marvel Mystery oil as an upper cylinder lubricant. It is $2.97 for a quart which will treat 100 gallons of fuel. How much does Lucas oil treatment cost. How much fuel will it treat and do you think it is better than the Marvel?
Re: Re: just used lucas oil product fuel treatment
I've used Lucas, and I run it through all vehicles I come in contact with. I dump the entire bottle in my car, even though it's only 13 gallons. Keeps it running great!
mine too, i dont get it, but what the hell, it works!
nope, but i'll look into it pretty soon. I'm due for another treatment. Where do i get it?
you get it at walmart and autozone
It works by doing what it says it does....lubricating the upper cylinder walls and valve components....and yes, lubricating the upper part of the cylinder is essential. It helps the engine run longer and quieter, but I've never used the stuff....but I'll surely give it a try now.
sounds interesting... im nervous putting octane booster in my car tho... i read an article about how in a round about way it can lead to a bad ignition coil, i think thats only if u use it a lot tho. the article is here
http://www.motorage.com/motorage/ar...il.jsp?id=68245 |
On behalf of Tim, Larry and the guys at NASCAR 4 Thanks for using the sponsor's product.
Alvin A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED. |
it has an octane booster in it
raises the octane to eliminate spark knocks. i copied that out of ur first post. i dont know if it will hurt on occasional use tho, i dont think it will, hell i liked what i read in here and put some in today lol. if my coil goes bad then i guess i know why lol |
