tune up
so i'm getting ready to do a tune up on my car. i want to put some ngk plugs and new wires, msd cap, new rotor, new valve cover gasket and oil pan gasket. any other suggestions on what more to do just to keep the teg in good maintenance condition
Re: tune up
I would just put on a new OEM distributor cap instead of the MSD, the MSD is made to use and aftermarket ignition system with it, unless you have an aftermarket ignition system then you would need the MSD cap.I would also replace the rotor button, and are the oil and valve cover gaskets leaking? If not then don't change them. If you do have a leaking valve cover gasket and you are going to replace it I would replace the rear camshaft seal that is right next to the distributor, preferably with a STR but OEM will do. If you are replacing any gaskets be sure to get some Hondabond it will save you some headaches.
Re: tune up
and you might wanna get a Valve Adjustment to. As for the cam seal do it and don't put that sorry ass stock one back. Get the STR one or if you cheep like me get one here https://shopping.lightningmotorsport...5&cat=0&page=2
98 MITSU GST, 1990 TURBO MOTOR 98 ACURA INTEGRA LS 88 HONDA CIVIC HB 97 HONDA CBR 600 91 HONDA CRX DX 89 JEEP ![]() ![]()
Re: tune up
Your link does not work for me.
Re: tune up
Re: tune up
Yep that is basically the same thing just silver and no logo. I actually think that it would look better than the STR IMHO.
Re: tune up
I think so to, i like yours. But when you look at $35.00 for and STI, and $15.00 for that one i like that one......
Re: tune up
alright so i'll go with the oem cap. both the gasket are leaking oil so they definitely need to be changed. i'll check out that ssite and see about getting that seal. why a valve adjustment though, just wanna know for what sspecific reason but i'll get it anyway. anything else to be done???
Re: tune up
here instend of me telling you about it this is a realy good write up http://student.ucr.edu/~ohe02/valveadj.html
