Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 02-02-2005, 12:14 PM
Nightwind's Avatar
Nightwind Nightwind is offline
85 eating slave cylinders
I have an 85 4 cyl 5spd, that keeps on wearing out the clutch slave cylinder, causing the clutch to slip back to the flywheel. I've found a partial remedy, just not leaving the clutch pedal depressed. However this still doesn't solve stop and go type traffic. Any Advice? I'm tired of having to replace the slave cylinder.
Old 02-02-2005, 05:12 PM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Re: 85 eating slave cylinders
Make sure you flush the system out real good. It sounds like you might have old dirt inside the lines that keeps wearing out your slave cylinders. Also make sure that the bracket isn't bent. It could be making the cylinder push a little sideways, and wear out the seal prematurely.
Old 02-02-2005, 08:28 PM
Nightwind's Avatar
thanks, i'll try that....any other advice anyone?
