Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 02-02-2005, 12:06 PM   #1
nekro6
Send a message via AIM to nekro6 Send a message via Yahoo to nekro6
98 Lumina Stalls won't restart until sits overnight
ok 98 lumina 3.1. It all started when i took it for a drive and it stalled out on me after like a block. Now after it stalls sometimes it will start back up and sometimes it needs to sit for a while then other times overnight. After it sets it starts no problem. After it stalls if you turn the key on the fuel gauge goes to empty and the fuel pump keeps cycling on about every 7 seconds. When the fuel pump kicks on the lights in the dash flash. It keeps doing this while the key is on oh and the fan relays try to kick on every time the fuel pump relay does. I have no clue where to go with this any ideas?
nekro6 is offline   Reply With Quote
Old 02-02-2005, 12:24 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 98 Lumina Stalls won't restart until sits overnight
Start with your battery connections, working your way back to the firewall and fuse/relay center, looking for loose or wet or chafed wiring. Also check the condition of the ground cable and any ground straps. You've got primary power or ground open/short somewhere. Can't be any more specific, you'll just have to hunt for it. Keep chasing the harness, you'll find it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 02-02-2005, 12:25 PM   #3
jeffcoslacker
Check the condition of the primary wiring down at the starter, too.
...empty gun rack.
Old 02-02-2005, 12:26 PM   #4
jeffcoslacker
In fact, the more I think about it, check that second right after the battery. Make sure you don't have a loose or half burnt fusable link down there.
...empty gun rack.
Old 02-02-2005, 12:27 PM   #5
jeffcoslacker
Leave the key on while you move the wiring around, you'll probably hear the relays chatter when you get near the problem.
...empty gun rack.
