Old 02-02-2005, 09:31 AM
karilyn1982's Avatar
karilyn1982 karilyn1982 is offline
Send a message via Yahoo to karilyn1982
Smell from 2001 Taurus....
I own a 2001 Ford Taurus. The mileage is currently 54,800.
Back in early December 2004 I noticed a burning smell coming from the front of the car, and could smell it when my vents were on inside.
At times it smelled like oil burning - but at times - it also smelled like radiator fluid. So I brought my car into the dealership right away - and they said that it was a leaking oil pan gasket.
So they 'fixed' the problem and gave me my car back. As soon as I got the car back - I could still smell the same smell (just not as strong.) I thought that maybe they had cleaned the engine (which is what it stated on my paperwork) and that the smell had to "burn off".
Well - it has been about 2 months since then - and the smell is still present, and much worse. Right now - it smells more like radiator fluid, though my car is not overheating, or anything, and I really smell it more when I turn on the vents in the car.
I called the dealership this morning - and I am scheduled to drop my car off tomorrow morning...I just wanted to post this here - and see if anyone else has had similar problem, or had any thoughts on what this could be?
Thanks so much in advance,
~ Kari ~
Old 02-02-2005, 09:59 AM
denisb denisb is offline
I'm thinking you might have had two problems and they only solved one the first time. If you smell coolant and it's worst when you have your heater on, I would suspect a bad heater core or a loose pipe/clamp. Usually, if you have a leaking heater core, you will get windows fogging/steaming up more.
Denis
Old 02-02-2005, 10:13 AM
Thanks so much for the reply.
You know - I have noticed that the window's have been getting pretty foggy lately. (But I just attributed that to the crappy weather that we have here in Michigan.) But of course that could very well be the heater core. I will have the dealership look into that.
Thanks again!
~ Kari ~
Old 02-03-2005, 09:02 AM
Re: Smell from 2001 Taurus....
Just wanted to update real quick about my car. I brought it into the dealership first thing this morning. I got a call from them just a little bit ago stating that there is a transmission leak, and they needed my authorization to run a diagnostic test. Of course I said yes - as it is all still under my extended warranty. I hope that this is all that is wrong with my car right now.
*Keeps fingers crossed*
~ Kari ~
