Old 02-02-2005, 03:49 AM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
what would cause this??
ok, my wife had my civic hatch today to go to work and when she was on her way home the check engine light came on(forgot to look what it was throughing) and then about 2 min later the car over heated really badly. so she stopped and had me come and get her. when i got there, water was running out of the water pump from where the seal is on the rod for the timing belt. also i noticed that my timing belt was badly ripped in a coupple of spots like it was about to rip off. what would cause this to happen?? it was fine till tonight. also the water pump and timing belt are like 3 months old too. i think something got in the timing cover and cought on it or something. but the water pump, i dont know. ill find out tomarrow when i go work on my car at a rayles parking lot. so much fun...
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 02-02-2005, 09:07 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: what would cause this??
Timing belt tensioner froze?
Old 02-02-2005, 11:17 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what is the seal on the rod of the timing belt ?
Team Lonely Drivers
Old 02-02-2005, 12:07 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Make sure that the cam and crank oil seals aren't leaking. The oil eats at the timing belt making it weak, which could cause unusual wear. But it sounds more like something is caught.
Old 02-02-2005, 12:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
if the check engine light came on then you can check your ECU for the code. the code will store in the ECU until it's cleared. so unless you pulled out your battery or some fuses, the code will still be in your ecu
sounds like the belt might have been too tight....too tight is why the belt was stretched (cracked)
too tight made the water pump over work and bust. car overheating was from busted water pump. you can tell the water pump is busted by leaking water. that is about the only way to tell your pump is busted as there isn't much to it, it's a very basic in design concept kind of part.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
