i have a 97 dodge ss/t it jsut recently started to give me problems. the check engine light is on and when i get to a stedy speed it will start to shake very bad.even does it when idleling. it doesnt back fire or stall out.thought it might be water in the gas but that wasnt it. maybe a fuel filter or something ? please help
justin wright |
Re: dodge ss/t
bleeddodge will probably have a list of the common problems for ya, but you may want to check into the VSS, or vehicle speed sensor. On some trucks it is located on the tranny, some it is on the rear axle, and it can cause all kinds of problems.
"I don't call it showing off or showing out... I call it you being mad because you can't do it!" The '88 Project Pickup |
Re: Re: dodge ss/t
thanks for the help i will check it out
justin wright |
Re: Re: dodge ss/t
Looks Like The Codes Are 12 43 42 443 43 55 Does That Sound Right?
justin wright |
Re: Re: dodge ss/t
I Doubled And Tripled Checked The Codes. They Are 12 43 43 43 43 55
justin wright |
Re: dodge ss/t
I wonder why it would give you the same code four times over? Maybe that means there are misfires on four cylinders? I don't know about that.
12 means the battery was recently disconnected. No big deal. 55 means end of codes, everyone knows that, but I just found this at the top of that page: "55 is end of codes - it's normal. Before you call your dealer or mechanic, consider that the blink-spacing is not always perfectly uniform, so if you see 23 23, it's probably just a single 55. (Codes are not repeated.)" That means the thing I said about four possible misfires is false. But look at this: 43 Peak primary coil current not achieved with max dwell time OR 43 Cylinder misfire OR 43 Problem in power module to logic module interface I remember you mentioned a code 42 before, so look at this: 42 Automatic shutdown relay circuit open or shorted 42 Fuel pump relay control circuit 42 Fuel level unit - no change over miles OR 42 Z1 voltage missing when autoshutdown circuit energized (SEE NOTE #6) Could be a number of things. I'd take it in.
My Mopars |
Re: Re: dodge ss/t
i got a dignostic test done today and found out that i have multiple cyclinder misfire on 1,4,8 what should i do next and can i do it myself thanks.
justin wright |
